Author Topic: Lowrance NDC-4 NMEA Cable Pinout  (Read 1366 times)
June 12, 2013, 11:50:35 AM
Read 1366 times
Joey
« on: June 12, 2013, 11:50:35 AM »
I saw it in a topic here, but then I could not find it.  So I decided to post this with a subject that could be easily found.  Not to mention the Lowrance cable does *not* come with any of this information.  Thanks Lowrance.
The Lowrance NDC-4 NMEA 0183 Cable has a 4 pin connector and 3 wires.
The pinout is:
Yellow: NMEA Transmit (or GPS out)
Orange: NMEA Receive
Black: Ground
Connections are easy to other devices once you realize that (regardless of color code):
The Yellow Wire [NMEA Transmit] connects to the RECEIVE WIRE on the Device.
The Orange Wire [NMEA Receive] connects to the TRANSMIT WIRE on the Device.
The Black/Ground wires should be connected together.
Joe
June 12, 2013, 11:56:42 AM
Re: Lowrance NDC-4 NMEA Cable Pinout
« Reply #1 on: June 12, 2013, 11:56:42 AM »
Good job Joe.  And just to be sure you get a good ground, run the grounds from both units to the boat ground bus.
June 13, 2013, 09:21:56 AM
225Explor
« Reply #2 on: June 13, 2013, 09:21:56 AM »
thanks for the post as I plan on linking my Standard Horizon vhf to my new Elite 7 chartplotter.
1995 Aquasport 225 Explorer
26\' Pacemaker Wahoo
June 13, 2013, 11:17:11 AM
Joey
« Reply #3 on: June 13, 2013, 11:17:11 AM »
I edited my post to add the (or GPS out) to the yellow wire on the cable.  The reason here was because I wired my Lowrance Elite 5 DSI to my DSC VHF Radio last night.  The VHF radio instructions said to connect the GPS out on my chart plotter to a specific wire on the radio, and did not mention anything about NMEA.
