Engines & engine woes
1995 evinrude 150 hp
Topic: 1995 evinrude 150 hp (Read 495 times)
June 09, 2013, 05:44:46 PM
Read 495 times
Thepipebender
June 09, 2013, 05:44:46 PM »
My evinrude won't go over 3000 rpm on the water....With ears on it will go over 5000....I get a chirp about every minute when I'm driving it.... Water cool coming out of engine even after a 10 minute drive... I thinking the thermostats might be the prob?would this cause the engine to run slow?I rebuild the carbs and the engine seems to run great at Idle and when I'm powering up,but then it stops and levels of.... Any ideas?
June 09, 2013, 06:51:53 PM
Re: 1995 evinrude 150 hp
June 09, 2013, 06:51:53 PM »
I realize yours is an Evinrude, but my old Yamaha does the same thing every time I get low on oil in the main tank.
June 09, 2013, 07:42:46 PM
June 09, 2013, 07:42:46 PM »
First off Never rev the motor that high on the ears, second Like Rick said it does sound like a low oil situation.
June 10, 2013, 09:58:36 AM
Thepipebender
June 10, 2013, 09:58:36 AM »
So what your saying is low oil will retard the engine or is that just for the alarm.
June 11, 2013, 07:50:32 AM
June 11, 2013, 07:50:32 AM »
My Yammy goes into "survival mode" which lowers and limits RPM to under 2500 to protect itself. When I add oil to the reservoir the alarm goes off and the motor returns to normal.
Not sure what my Johnson will do once I put it back on the 170.
June 11, 2013, 06:56:12 PM
Thepipebender
June 11, 2013, 06:56:12 PM »
Ok I found that 3 cylinders on the right side facing transom have no spark.I change the power pack ran it and and I still have nothing on that side
:x
:x
June 12, 2013, 10:46:25 AM
June 12, 2013, 10:46:25 AM »
Could it be a bad stator?
June 12, 2013, 03:53:02 PM
Thepipebender
June 12, 2013, 03:53:02 PM »
I found out it was the shift switch.It shuts off the starboard side cylinders.as soon as I unplugged it those cylinders sparked up..
