Author Topic: Any Easy way?  (Read 410 times)
May 31, 2013, 03:24:20 PM
Read 410 times
Geckert3611
Any Easy way?
« on: May 31, 2013, 03:24:20 PM »
I have the 222 inboard with the 2 tank set up..I currently just use the rear tank because I can see that there are no issues with it. My question is...Any easy way to check the integrity of the under deck mounted tank for leaks without removing the deck? I really dont like having 50 on the stern all the time and none in the hull it just sits way to low in the back. Thanks
May 31, 2013, 03:54:57 PM
Callyb
  • MidWest
Re: Any Easy way?
« Reply #1 on: May 31, 2013, 03:54:57 PM »
Plug the inlet, vent and outlet and pump it up to 4-6 psi with air. If it holds for an hour you should are good to go! If it starts loosing pressure right away (and assuming you can access through a deck plate) take the hoses out of the equation and check the tank by itself.
Carl
___________________________
May 31, 2013, 04:56:58 PM
Geckert3611
Re: Any Easy way?
« Reply #2 on: May 31, 2013, 04:56:58 PM »
I kind of figured that would be the answer...LOL I actually was just kind of filling it with water and calling it a day. I would rather use it for fuel tho. Thanks.
