Author Topic: Lost my Oil Pan at 4500 RPM  (Read 626 times)
May 22, 2013, 01:57:54 PM
Read 626 times
pzart
« on: May 22, 2013, 01:57:54 PM »
Running along at about 45 MPH thru St Joseph Sound, started losing a little speed, checked the gauges......no oil pressure. Dropped the throttle, turned the key off.....checked the dip stick......no oil. :shock:  :shock:  Add 3 quarts, it just starts registering on the dip stick, try turning it over......she is turning over hard, sit down, drink 2 beers :evil: .....call Boat US for a tow. While I am waiting I check the oil again.....empty again :shock:  :shock: Stand on my head to look under the motor....FOUND MY OIL :cheers:  :cheers: its in the bilge, all 8 quarts of it :?  :? Sit back down and drink 2 more beers, Boat US shows up pretty quick and back to dock, once at home, I drain my oil from the Bilge plug :roll: and with flashlight and mirror in hand I find the rusted thru holes in the bottom of the pan. Sit down and drink more beer. :drunken:  :drunken: Sitting there drinking and reminiscing over the last few hours and beer, I have come to the conclusion that I should have never topped off my oil that morning......the extra weight ruined my oil pan :shock:  :shock:
That was almost 2 weeks ago now, this is why I have been a little quiet recently. Currently the motor is sitting in my garage, upside down, waiting for the Crank kit, oil pump, new pan and gaskets. Which should be in today. I can work on my own engines, but had never had to remove one from a boat as big as this WC 248 Sportsman. For a bit I was lost, but I found a little marina locally that if I took everything apart, they would pull the engine with their forklift for 35 bucks out, 35 bucks back in :cheers:  :cheers:  Trying to get her done by the Holiday weekend, but I don't think I am going to make it.
My Fat and Skinny Water Rides
My 1982 WellCraft Sportsman 248 350EFI/BravoIII
My 1975 AquaSport 170 110 Evinrude
May 22, 2013, 02:08:30 PM
Re: Lost my Oil Pan at 4500 RPM
« Reply #1 on: May 22, 2013, 02:08:30 PM »
Sorry to hear it, that sucks.  I've seen it before though, thats the bad part about those oil pans in the bilge, the paint hides the corrosion, and they rot from within, my neighbor almost met the same fate, but discovered it while trying to get the drain plug out, almost ripped the whole drain plug insert out of the rotted pan.
May 22, 2013, 04:48:38 PM
« Reply #2 on: May 22, 2013, 04:48:38 PM »
Ah, the joys of owning an I/O or I/B.  Might want to coat that new pan in epoxy, Paul!  And while you've got the motor out, might as well throw a new bilge pump and float down in there...
May 22, 2013, 07:38:18 PM
« Reply #3 on: May 22, 2013, 07:38:18 PM »
That sucks Paul.  That boat would have been a good one to camp with us up at CR.
May 22, 2013, 10:11:20 PM
« Reply #4 on: May 22, 2013, 10:11:20 PM »
Was that a cast aluminum pan? or a steel pan? somewhere I have a cast aluminum SB 350 oil pan.
May 23, 2013, 12:05:50 AM
icemanbryan
« Reply #5 on: May 23, 2013, 12:05:50 AM »
I thought the oil pans on an IB were Stainless or Aluminum?
May 23, 2013, 07:32:15 AM
pzart
« Reply #6 on: May 23, 2013, 07:32:15 AM »
Quote from: "wingtime"
I have the one piece rear seal, if thats the design pan you have I would be interested. I looked at new aluminum ones and didn't fit my wallet :lol:
May 23, 2013, 07:33:16 AM
« Reply #7 on: May 23, 2013, 07:33:16 AM »
Quote from: "icemanbryan"
Far as I know Bryan, both Merc and Volvo use stamped steel oil pans.  Of course you can buy aftermarket aluminum or SS, but out of the factory?  Steel.  And as Paul said, up there in $$...
May 23, 2013, 07:37:11 AM
pzart
« Reply #8 on: May 23, 2013, 07:37:11 AM »
yea, but you have different issues with both....I was very suprised how easy it was to remove the motor, had it ready to pull out in a hour time. All maintenance items hard or impossible to do while engine is in will be done for sure
May 23, 2013, 07:43:30 AM
pzart
« Reply #9 on: May 23, 2013, 07:43:30 AM »
Quote from: "RickK"
yea, I had already decided to run the boat to CR next time, or whereever, fuel and cost would be about the same....I have the 300 HP Gen+ motor that has the Bravo III drive....it will sip fuel at cruise speed, 27mph and 5-6 gallon per hour. WOT is 52mph....and watch the fuel guage drift south :mrgreen: boat weighs around 5000 loaded :shock:
May 23, 2013, 07:28:40 PM
icemanbryan
« Reply #10 on: May 23, 2013, 07:28:40 PM »
Good to know,
I go out in a friends SkipJack sometimes.
May 23, 2013, 09:30:41 PM
« Reply #11 on: May 23, 2013, 09:30:41 PM »
The one I have is for a two piece rear seal.
May 24, 2013, 05:39:48 AM
« Reply #12 on: May 24, 2013, 05:39:48 AM »
Quote from: "pzart"
Sweet burn rate - at 27 I'm burning 14-16gph  :shock:
May 24, 2013, 08:45:58 AM
pzart
« Reply #13 on: May 24, 2013, 08:45:58 AM »
thanks for the offer, I will remember your good will....
May 24, 2013, 08:51:37 AM
pzart
« Reply #14 on: May 24, 2013, 08:51:37 AM »
Quote from: "RickK"
Quote from: "pzart"
yea, when I first got the boat I didn't believe the PO, but he was right....I guess its all in the combination of proper equipment.....I'll put 30 bucks in, cruze 1/2 hour out to the reef, fish and then come back and swear I didn't use it all.....I like it
