Thanks guys. Just for the record it's a 22 Family Fisherman (cuddy cabin) so the run to the cabin versus a center console version is a little longer. If I can mount the pump up in the cabin with no performance issues then that's probably what I'll do. It's at least 15' though, is that distance OK? If it is, then I can keep the hoses basically the same length and run them together all the way up. That would solve a lot of my problems with pump location and hose routing. There really aren't any other storage/mounting options for that pump.
Quote from: "Curious"Thanks guys. Just for the record it's a 22 Family Fisherman (cuddy cabin) so the run to the cabin versus a center console version is a little longer. If I can mount the pump up in the cabin with no performance issues then that's probably what I'll do. It's at least 15' though, is that distance OK? If it is, then I can keep the hoses basically the same length and run them together all the way up. That would solve a lot of my problems with pump location and hose routing. There really aren't any other storage/mounting options for that pump. That will work fine. If you need longer tubing let me know and we can send it to you for the cost of shipping only.TomBennett Marine
Tom,I measured (roughly) from the port side which is the furthest, to where I'm thinking of mounting the pump in the cabin and it is roughly 22' minimum to 25' max. I'm being safe to account for a curves and loops. Can I get the hoses in one continuous length so I don't have to couple it? So I'll need the hose, 2 nipples (2 1/2"if possible), 2 90's and the kit should have everything else right? I might be able to get the nipples and 90's locally so then all I would need is the hose.Also, what is the best way to contact you, should I just PM you here or contact you through Bennett?Thanks again, Tom, and thanks to all for the tips and advice. Knowing that I can mount the pump further away from the transom opened up more options for me that i hadn't been thinking of. I thought it had to be close to the transom and as I said, this boat just doesn't have any storage compartments or below deck space to mount the pump.
