Plumbing
bildge pump
Topic: bildge pump (Read 696 times)
April 25, 2013, 03:30:28 PM
Read 696 times
sonny200ccp
bildge pump
April 25, 2013, 03:30:28 PM »
im trying to replace my bildge pump and i cant figure out how to get to it. i can put my hand in the hole that is located in front of the
built in bait tank and barely touch it but i cant see it while i do this. any idea would be greatly appreciated. i almost forgot, i have a
1984 200ccp. thanks for any help.
April 25, 2013, 04:48:27 PM
jdupree
Re: bildge pump
April 25, 2013, 04:48:27 PM »
The CCP bilge access is "very tough" with the original splashwell in place. I assume you have a pie plate to access it? When I had my 200 CCP, I considered removing the pie plate and installing a small hatch to give me better access. The pie plate on my 200 CCP, was located at the base of the splashwell just inside the cockpit and it was mounted vertical. There should be room there to add a bigger pie plate or install a hatch.
This should be your layout? This was my 200 CCP. The verticle pie plate at the splashwell is where my access was. I would try and find a small rectangular hatch to replace that pie plate.
John L. Dupree, III
AQABLA84E999
Member #257
April 26, 2013, 08:42:10 AM
sonny200ccp
Re: bildge pump
April 26, 2013, 08:42:10 AM »
that is exactly my boat situation and a great idea! thanks for your interest in my problem.
i am now on the hunt for a hatch. thanks jd.
May 01, 2013, 10:36:54 AM
ktisdall
NorthEast
Re: bildge pump
May 01, 2013, 10:36:54 AM »
What I did is to install an access port (8") in the aft wall of the tank compartment. From there you can easily reach and see the stock pump location. I also have a 1984 200ccp.
See:
http://www.classicaquasport.com/gallery ... cc&cat=500
You can leave it at that, or what I did is install another inspection plate (clear) in the floor piece above the tank, at the aft end. I can see if there's water in the tank compartment and also open that bilge access and get to the pump if needed.
--Kevin
May 01, 2013, 12:35:07 PM
Purgatory
Re: bildge pump
May 01, 2013, 12:35:07 PM »
May 07, 2013, 08:39:13 AM
sonny200ccp
Re: bildge pump
May 07, 2013, 08:39:13 AM »
kevin, i like what you did. i was hoping not to get so deep into the boat. i might just have to, thanks for your input.
Plumbing
bildge pump
