Paints, topsides and bottom and Gelcoat Topics
wax for fiberglass
Topic: wax for fiberglass (Read 903 times)
May 30, 2006, 10:50:16 AM
Read 903 times
jdupree
wax for fiberglass
May 30, 2006, 10:50:16 AM »
Could anyone tell me the best wax to use on fiberglass? I know that there are many out there but I need some opinions. The hull looks good but wanted to bring back some shine to the inside of the boat. Thanks in advance for the suggestions.
John L. Dupree, III
AQABLA84E999
Member #257
May 30, 2006, 11:17:30 AM
osprey170
May 30, 2006, 11:17:30 AM »
Depending on how dull the gelcoat has become you could consider some mild rubbing compound. 3M makes some good stuff that cuts pretty quickly - again it all depends on how bad it is. Mine was pretty bad so I used the 3M stuff and a buffer, worked great. You can then put a coat of teflon wax with some UV inhibitors in it to make the shine last.
If you don't need to go that drastic then use a good Marine wax and lots of elbow grease.
1985 Osprey 170
May 30, 2006, 04:54:48 PM
ddd222
Guest
May 30, 2006, 04:54:48 PM »
3m definately, if you need a little more than just a wax, try the 3m color restorer, awesome, the harder you rub it on, the brighter it comes out, and a one step process
May 30, 2006, 08:20:57 PM
May 30, 2006, 08:20:57 PM »
Everyone around here recommends Collinite Fleet Wax as well as their other fiberglass products. Do a google search and you will come up with tons of comments on different forums.
http://www.collinite.com/marine.htm
wax for fiberglass
