Author Topic: 222 Bildge hole  (Read 2113 times)
April 16, 2013, 11:12:03 AM
Read 2113 times
2805Justin
222 Bildge hole
« on: April 16, 2013, 11:12:03 AM »
This is my first classic aquasport so please understand I know this is probably a stupid question. The boat has a hole (through the hull) just above the drain plug that has a threaded end on the inside of the hull. Can someone tell me what this is for? I assume it is for a bilge pump of some sort but it would be almost a 90 degree bend on the inside of the hull if attach anything to it.
Alabama - 1973 222
April 16, 2013, 11:29:04 AM
Re: 222 Bildge hole
« Reply #1 on: April 16, 2013, 11:29:04 AM »
This sounds unusual.
Can you send a pic?
April 16, 2013, 11:45:20 AM
2805Justin
Re: 222 Bildge hole
« Reply #2 on: April 16, 2013, 11:45:20 AM »
I will send pics at lunch
Alabama - 1973 222
April 16, 2013, 12:05:19 PM
jdupree
Re: 222 Bildge hole
« Reply #3 on: April 16, 2013, 12:05:19 PM »
It sounds like some sort of livewell pickup to me.   Here is a picture of my CCP when I first got her.  Look above the drain plug.  Does it look similar to mine?  Being a 1973, obviously not a CCP but the 222 might have had a similar setup.
John L. Dupree, III
AQABLA84E999
Member #257
April 16, 2013, 12:07:25 PM
Re: 222 Bildge hole
« Reply #4 on: April 16, 2013, 12:07:25 PM »
Sounds like a raw water pick up on an 80s model CCP for the transom live well.
Didn't know they had them on the 73 22-2.
I'll look for a pic.
Edit:
JD you ol'dog, you beat me to it.
April 16, 2013, 12:30:31 PM
2805Justin
Re: 222 Bildge hole
« Reply #5 on: April 16, 2013, 12:30:31 PM »
If I recall it is a little higher than that since mine has twin motors and the area is clear. The hole comes out just above the deck I will take pictures on lunch.
Alabama - 1973 222
April 16, 2013, 12:40:00 PM
Re: 222 Bildge hole
« Reply #6 on: April 16, 2013, 12:40:00 PM »
OK then, it looks like this.
Top left pic. Deck drain.
http://www.classicaquasport.com/gallery ... 75&cat=544
April 16, 2013, 01:20:56 PM
2805Justin
Re: 222 Bildge hole
« Reply #7 on: April 16, 2013, 01:20:56 PM »
That is it. But the problem is it floods the boat when I put it in the water. But if I plug it there is no way for the deck to drain when out of the water.
Alabama - 1973 222
April 16, 2013, 01:29:11 PM
2805Justin
Re: 222 Bildge hole
« Reply #8 on: April 16, 2013, 01:29:11 PM »
Noticed I plugged the threaded side with an oil bottle cap so that I could use it for the day
Alabama - 1973 222
April 16, 2013, 01:33:21 PM
2805Justin
Re: 222 Bildge hole
« Reply #9 on: April 16, 2013, 01:33:21 PM »
Thank you so much for the info. That is really what I was after if it was a drain I did not want to plug it.
Alabama - 1973 222
April 16, 2013, 01:35:37 PM
Georgie
Re: 222 Bildge hole
« Reply #10 on: April 16, 2013, 01:35:37 PM »
Justin,
These drains on almost all of our boats tend to take on water at launch and drain once the boat is sitting level.  If your boat still takes on water when sitting level and with only one or two folks aboard, then I imagine she's somewhat heavy or waterlogged (very common with these old boats) and you'll just need to keep the hole plugged at all times.  Your simple option is just to keep a couple flip-lever plugs in your transom until you need to drain your deck.  Personally, I launch with my transom plugged to prevent my deck from getting soaked, but if things get wet or rough I pull the plugs to let excess water drain from the deck.
Does this conversation below help at all regarding your options?
http://www.classicaquasport.com/phpbb3/viewtopic.php?f=1&t=10644
Ryan
1979 246 CCC
1987 Wellcraft 18 Fisherman
April 16, 2013, 01:47:00 PM
2805Justin
Re: 222 Bildge hole
« Reply #11 on: April 16, 2013, 01:47:00 PM »
Perfect that is exactly what I was looking for and was about to be my next question. Yesterday I thought of using a ball scupper but did not want to if it was originally a water return. Thank you for all of the help this page has been more than amazing.
Alabama - 1973 222
April 16, 2013, 08:23:45 PM
Re: 222 Bildge hole
« Reply #12 on: April 16, 2013, 08:23:45 PM »
You said it was threaded from the outside?
April 16, 2013, 08:51:37 PM
Re: 222 Bildge hole
« Reply #13 on: April 16, 2013, 08:51:37 PM »
Quote from: "RickK"
 "The boat has a hole (through the hull) just above the drain plug that has a threaded end on the inside of the hull".
I prefer a good Merlot myself. :mrgreen:
April 16, 2013, 09:00:44 PM
Re: 222 Bildge hole
« Reply #14 on: April 16, 2013, 09:00:44 PM »
Quote from: "Capt. Bob"
Quote from: "RickK"
:oops:
I knew I read threaded somewhere - I think what got me thinking was "inside the hull", not inside the boat.
