I winterize my boat every november and open it in march. My tank is usually about 1/2 full between 80 and 90 gals. of ethanol fuel. I double dose it with StaBil and have no problems I usually take her out for a run without adding gas and before I change plugs and she runs fine. The problem is more likely the hoses being eaten away by the ethanol and not enough stabilizer when you winterize.Get some gas out of the tank in a clear bottle make sure you get it from the bottom of the tank without rocking the boat all around let it settle if it seperates you will need to drain off the rest until it does not seperate anymore and you will be good to go. One more thing do not add any of those tank cleaners or you will have more problems and dont use any treatments with any kind of alcohol in it.
Ethanol is a tank cleaner! It will break down any old varnish built up in your fuel system left over from old non ethanol fuel. The varnish will show up as tiny golden brown flakes in your fuel filter. Don't get avgas it is LOADED with lead! Yes they call it 100 Low Lead but don't let the name fool you it has four times the lead in it than the old 80 octane avgas. It is a very stabil fuel that stores well but I'd guess your gonna pay $6 or more per gallon for it. Couldn't you find a non ethanol source on Pure gas.org?
Now that's the kind of information I am talking about, here we have a northern member who lets his ethanol fuel set for the winter.....us Florida members rarely let ours set that long......with basically no troubles or issues.....I like it....hand pump off the separated crap on the bottom and move on. Maybe we are over thinking this old ethanol fuel issue.
They do have me a little concerned though and now I don't know what to do, if a little oil in the gas can save a motor if the pump stops working maybe I should just keep doing it.
OK, let's over-think just a little more. "three tall boys" Better start the still up right after Christmas.
aside from the fact that we had 71 and a half gallons of pure recreational gasoline.....why start the still except for drinking......
8) 8) Mad Max world. 8) 8)
