Well, Aaron, she's basically ready to go home...Edit by Admin: BeforeAfter: You now have an OMC trim gauge, where up is up, down is down...All the gauge lights work off the nav lgt switch.Drop down the door, and there is your batt switch and main breaker...And you actually have some uncluttered storage space, you can access your fuses, and you can change your batts without tearing up a bunch of chit!What I couldn't do was tie in the newer harness to the old engine plug to get the key to shut the motor down. If your newer harness was intact, I could probably do it. But the way the newer harness was spiced into? Give me another couple hundred and I'll figure it out!Give me a buzz on my cel when you want to come get her...
CB,Bob saw this thread and asked me to thank you for him, so thank you, he appreciates it
