Author Topic: Main fuel line.  (Read 504 times)
April 02, 2013, 09:51:27 AM
Read 504 times
jd1miami
Main fuel line.
« on: April 02, 2013, 09:51:27 AM »
I have a 1994 22.5' Aquasport explorer and need to replace the fuel line from the main tank to the water separator.  Does anyone have a schematic of the hull and ribs or how the line is fed.  When I pull on it it does not give and when the line leaves the tank it goes forward before it goes back to the transom.
April 02, 2013, 11:53:29 AM
Re: Main fuel line.
« Reply #1 on: April 02, 2013, 11:53:29 AM »
OK JD, look similar to this?
viewtopic.php?p=37022#p37022
On my 91, the fuel line ran (still does after replacement) from the pick up along the top of the tank to the rear bulkhead of the tank compartment. At that point, it penetrates this bulkhead and then travels along the inside of the starboard stringer. It is attached to the stringer with hose supports like these.
http://www.westmarine.com/webapp/wcs/st ... Vr6vzemx7w
It then enters from the bilge through the passage between the stringer and transom.
Your boat has the Euro Transom and you can't remove the hatches to access the bilge area as can be done on the 91-93 model EXs so....
You may have to abandon the existing line and run a new one (might be tricky) on a slightly different route. I've attached a file of your stringer layout from the 94 catalog. This page exists in the Photo Gallery under "1994 catalog". It's not the easiest to read but I'm hoping that by attaching the file, you can save to your computer, open it with a photo editor and enlarge. In any case, note two things.
First, the line drawing on the catalog sheet shows the tank location.
Second, the photo of the guy glassing (I guess) gives you a good visual of the stringer/bulkhead layout. Euro Transom section aside, it is a mirror copy of my 91 layout.
You may need to snake the hose though the notch on the stringer (there's) one on either side of the tank and work back to whatever side your water separator/filter is located. My concern would be line attachment to reduce the chance of chafing.
Hope this helps, at least from an understanding of your model's construction.
April 02, 2013, 05:00:40 PM
Re: Main fuel line.
« Reply #2 on: April 02, 2013, 05:00:40 PM »
So there is that damn rigging tube - never did find it  :oops:
April 04, 2013, 01:06:34 PM
jd1miami
Fuel tank gas line replace.
« Reply #3 on: April 04, 2013, 01:06:34 PM »
I have a 1994 22.5' explorer and need to replace the fuel line from the tank to the water separator.  When I pull it, it does not give and it goes forward before it runs aft. Doen anyone know how to feed a new line?.
April 04, 2013, 03:11:56 PM
Re: Main fuel line.
« Reply #4 on: April 04, 2013, 03:11:56 PM »
See above.
