Author Topic: Magic Tilt Cross-Member Weep Holes  (Read 819 times)
April 01, 2013, 08:56:09 PM
Read 819 times
dxs217
« on: April 01, 2013, 08:56:09 PM »
I have a new magic tilt aluminum trailer.
There are no weep holes on the bottom side of the cross members.
All of my other aluminum trailers had a weep hole drilled in the center of the cross members.
Should I drill one?
Any help is appreciated.
Dan
1999 215DC
Evinrude 200 FICHT
April 07, 2013, 07:10:15 PM
Re: Magic Tilt Cross-Member Weep Holes
« Reply #1 on: April 07, 2013, 07:10:15 PM »
my magic tilt trailer doesn't have any holes also, i do spray freshwater inside each crossmember after dunking it, its an '07
May 09, 2013, 05:06:08 PM
BStrailer
« Reply #2 on: May 09, 2013, 05:06:08 PM »
Is your cross members aluminum or Galvanized ?
If they are aluminum it will not hurt to drill a 3/8 hole no bigger right in the bottom center.
But if they are galvanized they are going to rust if you do drill or if you don,t hard call .
you could drill a hole but keep plenty of paint on the hole area. really no good solution either way
Cliff@ B&S Trailer
