Author Topic: What does the push button breaker control on my 215 DC?  (Read 423 times)
March 21, 2013, 12:15:37 PM
Read 423 times
Grizzly65
« on: March 21, 2013, 12:15:37 PM »
The wonderful black box breaker panel by my batteries on my 96' 215 DC does not have the breakers labeled. The two on the left and  the red center one are locked in the "in" position while the one on the right is tripped "out". What does this breaker control? I am going through and replacing old original pumps, but may not need to if the breaker is bad. My bilge pump and fishbox pumps are not working and have definitely seen better days. If it is bad where do I get a new breaker to replace it? I did see some good pictures of the back of the box on another post, just not the front.
Thanks in advance for the help.
March 21, 2013, 12:28:44 PM
Re: What does the push button breaker control on my 215 DC?
« Reply #1 on: March 21, 2013, 12:28:44 PM »
The big red one is the main power supply circuit breaker for your helm power feed.  The other three should be front and aft bilge pump floats and the stereo memory.  I say should since your boat is a different model than mine and we have seen them set up a little differently depending on the year.
March 21, 2013, 07:41:13 PM
« Reply #2 on: March 21, 2013, 07:41:13 PM »
This one should do the trick...http://shop.genuinedealz.com/Items/gim- ... 2030%20AMP
Think that breaker may have been 40A, but 30 should do you fine...
