I just started my tank replacement yesterday. Photos and progress to follow. Tom.
broke in to three segments
Quote from: "fishinonthebrain"broke in to three segmentsWhat do you mean broke in to three segments?
Tom....see that "new topic" button on the top or bottom left of the screen? Give it a shot. I'd nix the barmat thing. Sure, "water" would drain fine, but "moisture" would be caught in the many contact points where the tank sits on the mat. Aluminum straps can be reused for sure. Just make yourself some starboard chocks or spacers for the corners and 5200 those to the tank before tightening the straps. Prevents any moisture from being trapped between the strap and the tank. Taking into account known ways to reduce electrolysis and wear, many of us here will recommend you otherwise follow Curious' approach which is based on the "Pascoe" method. Replaced my father's 170 tank the same way, though I used a single flap of rubber from a bike tire to prevent wear between the straps and tank and forgot to 5200 to tank...starting to regret that now that I realize the small rubber pieces will definitely hold some moisture. That's the entire reason that I haven't posted a thread for his tank replacement.
