well if you want to get rid of the old tank let me know i might come pick it up off your hands. is the old tank a 54 gallon as well? and where exactly are you located and let me know a price if u dont mind. thanks
You could add another strip each to the inside two
Cant tell for sure from the pics, but you want an air gap between that tank and the PT. Make sure you isolate the tabs from the PT when you fasten them too. Corrosion waiting to happen. Stop sign pole wouldnt have been my first choice for supporting the lid haha, but if its nowhere near the tank then you should be good..
Just getting to this thread. Nice work so far.Re: the bow in the bottom of the tank box, I do NOT think you should add extra strips. MUCH more likely to isolate pressure points near the center that way rather than evenly distributing the load across the bottom of the box.IMO - leave as is and let the weight of the tank and some fuel equilibriate the install.
