check the blue plug
Bryan, there are several fuses on the motor, but I doubt that's the issue, as the ign power feed (yellow wire) is receiving power (hour meter running), if the main fuse had blown on the powerhead, everything would be dead. The way to install an hourmeter on a Yam is to tap into the yellow wire off the gauge harness for positive, black of course for ground.The place to start of course would be your batt cables. Not just those on the batts themselves but also the cable lugs on the backside of the batt switch. Yes, that means pulling down the switch, but I would recommend it...
