thank you everyone for the feedback. very helpful. i am still researching what design i should go with when i make the bracket and what aluminum to use. whether it be squared tubing or round tubing and what size. i was thinking squared aluminum tubing would work best and maybe around 1 1/2". And i also looked up that evercoat feather fill and that does look like some good stuff so i think im going to put 2-3 coats of that on the boat with some sanding in between coats and then a top coat after that. got to find a good reasonabally priced topcoat as well. any input on that would be appreciated too, thanks!
