Aquasport Discussion
motor size ?????
Topic: motor size ????? (Read 725 times)
March 07, 2013, 05:44:53 PM
Read 725 times
flatsfisher
motor size ?????
March 07, 2013, 05:44:53 PM »
Can I put a 2002 yamaha 150 0n my 1975 17 aquasport?????
March 07, 2013, 07:23:24 PM
Re: motor size ?????
March 07, 2013, 07:23:24 PM »
I think that the boat was rated for a 130 if I remember right. Spend some time in our PhotoGallery - we have a ton of stuff on the first page.
http://www.classicaquasport.com/gallery/showphoto.php?photo=2717&title=as-170-sales-sheet2-19&cat=552
March 07, 2013, 07:32:57 PM
Purgatory
March 07, 2013, 07:32:57 PM »
Quote from: "flatsfisher"
Would not recommend it. A 3 cyl 90 would be perfect. Keep the weight down.
A four cyl. 2 stroke Merc would max her out IMHO. For sure not a six.
March 07, 2013, 08:08:13 PM
pzart
March 07, 2013, 08:08:13 PM »
the 1975 model v4 johnson/evinrudes 120-140 hp weighed in around 365 lbs, use that as your max weight for your 17 ft
the 2002 150 yamaha v6 weighs in around 465 lbs, too heavy IMHO
I have the 1989 model evinrude 110 hp that weighs in around 320 lbs, I'll make sure I throw all my gear in the front. seems to have plenty of power. but we always seem to want more.... :bounce:
My Fat and Skinny Water Rides
My 1982 WellCraft Sportsman 248 350EFI/BravoIII
My 1975 AquaSport 170 110 Evinrude
March 07, 2013, 08:55:44 PM
March 07, 2013, 08:55:44 PM »
Back in the day ('75) you'd find 70s, 90, maybe an inline 6 Merc 115 on them (if they were made back then - the motor that was on my 170 when I bought it) and they didn't weigh much - maybe 300 lbs max, less for the 70 but not much.
The low transom (notch 8"ish above the water) should make you think twice about putting more weigh on the aft - especially when you come off plane
My 115 is about 320 and is about the max I would put on it. I wouldn't mind getting an old 115 merc inline 6 and somehow blowing it out. There was a posting on one not too long ago here. :twisted:
Speed, the ultimate goal it seems
Guilty as charged.....
The hull is the hull and the speed you get will depend on a few things like whether you have gelcoat or paint on the bottom, waxed?, other than that little things like weight distribution, trim, prop, etc will tweek it a bit. Best I have gotten with bottom paint is 40. Some have gotten more, some less.
March 07, 2013, 09:33:04 PM
March 07, 2013, 09:33:04 PM »
130 is the max rated HP on my 170. I have the 60 degree V4 90 loop charged on my 170 and she gets up on a plane like RIGHT NOW! Even with three people and a bunch of gear. A 150 would be scary on a 170 and it would weigh WAY too much.
March 08, 2013, 09:17:50 AM
Mechanical Master
March 08, 2013, 09:17:50 AM »
As others have said, a 1975 Aquasport 170 has a maximum HP of 130. A 90 works well and a 115 seems to be the hot setup. This boat also has a 20" transom, so watch out for that as well.
See ya on the water!
March 09, 2013, 06:00:44 AM
flatsfisher
March 09, 2013, 06:00:44 AM »
Thanks All I'll keep my 88 spl. The 150 was a gift
March 10, 2013, 09:01:49 AM
200CCPMerc200
March 10, 2013, 09:01:49 AM »
Wow 465lbs for a 150 ? Thats one fat mota' no wonder they are slugs, Inline 6 mercs have been around since the late 50's the '59 mark 75 is an I6., i would put a 90/115 /150 inline Merc on it myself, still a dime a dozen, easy to fix, and strong.
Aquasport 200 CC Pro, 200 Merc,15hp Honda,Hydrostream Varmint Bassboat,2.4 Merc Bridgeport, Shadow VT200, tunnel hull,merc., 225 Promax.
motor size ?????
