Author Topic: Scott's steering issue...  (Read 1248 times)
March 06, 2013, 08:04:36 AM
Re: Scott's steering issue...
« Reply #15 on: March 06, 2013, 08:04:36 AM »
Going to HD this morn to pick up some sort of polishing wheel for my bench grinder.  Basically looking at what I would call minor surface rust...very minor.  Any suggestions?  Maybe a real fine wire wheel?
March 06, 2013, 10:46:28 AM
« Reply #16 on: March 06, 2013, 10:46:28 AM »
Bench grinder, wire wheel :shock:
How about some Filtz and a buff ball
http://www.flitz.com/p-36-buff-ball-supermini.aspx
March 06, 2013, 01:20:29 PM
« Reply #17 on: March 06, 2013, 01:20:29 PM »
Nando, picked up a $4.50 wire wheel for a drill this morn...so far, the results are excellent!!! :thumleft:  :thumleft:  :thumleft:
March 06, 2013, 01:34:55 PM
« Reply #18 on: March 06, 2013, 01:34:55 PM »
Bob it sounds like you have it under control.  For future reference I wasn't sure if you have a right angle die grinder or not.  If you do I've had really good luck with the roll-lock Scotch Brite discs for that type of stuff.  Of course you can probably pick one up from Harbor freight for $15 or less.
March 06, 2013, 02:14:43 PM
dburr
« Reply #19 on: March 06, 2013, 02:14:43 PM »
Lowes has in the hand tool section hard and soft buffing wheels, rouge and arbors.  They completely KILL in a drill press.  For years I have slowly collected bearings, shafts etc to make a fixed setup.. No need with the wheels from Lowes..   :thumright:
FWIW..
On the hard stuff Bob I have had good luck with wet sanding with silicon carbide 400, then jumping to 1000, then onto the wheel.   Don't know how I survived without the wheels..  Speaking of tools not to survive without, have you tried cut down hacksaw blades in the HF body saw? For $9. That was a complete steal! :thumright:  :thumleft:
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
March 06, 2013, 05:44:48 PM
« Reply #20 on: March 06, 2013, 05:44:48 PM »
Well, took it all apart, about 1/2 hour later, including cleaning up the threads...
We have a happy tie bar, worthy to go on an un-named boat.  The wire wheel did the trick as the surface rust was minor, like I said.
Dave, learned the 1/2 hacksaw blade trick many moons ago at Stamas.  I keep several on hand just for that purpose... :thumright:  :thumright:  :thumright:
March 06, 2013, 06:34:26 PM
dburr
« Reply #21 on: March 06, 2013, 06:34:26 PM »
Thank you Yan Quetze!  I now face the rice paper without fear.. :salut:  :mrgreen:
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
March 06, 2013, 07:04:51 PM
« Reply #22 on: March 06, 2013, 07:04:51 PM »
SB,
Might there be a "before" pic of that bar?
March 06, 2013, 07:26:30 PM
« Reply #23 on: March 06, 2013, 07:26:30 PM »
Quote from: "Capt. Bob"
SB,
Sorry CB, was actually thinking about that, but stupid me...
Scott and Farley can attest to it's "former" condition...
The motors are set up on 26" centers, so I'm gonna start with a very minor toe-in, 25 1/2" on the tie bar.  Given that the extension plates will move the tie bar about 3" forward of the steering arms, the dimension will probably be more like 25 3/4", maybe 25 5/8"...very minor, but I've always believed the thrust of the props aimed towards the keel doesn't hurt...
March 06, 2013, 07:32:09 PM
« Reply #24 on: March 06, 2013, 07:32:09 PM »
I have no doubt.
Better the fact that no evidence of the "supplied" product is available. :roll:
I'm sure the supplier got a "deal" on the product...... :mrgreen:
Looks good now though. :thumleft:
March 06, 2013, 07:43:38 PM
« Reply #25 on: March 06, 2013, 07:43:38 PM »
I have no doubt.
Came off Miss Marco...along with many other dubious parts, several of which have made their way to the Hernando county landfill by now... :shock:  :shock:
March 06, 2013, 08:06:52 PM
« Reply #26 on: March 06, 2013, 08:06:52 PM »
I'm sorry guys and gals but I need to lock this topic down too.  If you have questions about why please PM Gran and he'll explain his request to not start any more threads on Miss D.
