Author Topic: Rookie mistake  (Read 1546 times)
March 05, 2013, 08:46:32 AM
Read 1546 times
florida196
Rookie mistake
« on: March 05, 2013, 08:46:32 AM »
Installed my new transom in the boat saturday by mixing up a bunch of cabosil and resin.  Probably using way to much. Let it set for two days.  Mounted it using 2x4 along the outside skin bolted threw new core to tighten everything down to squeeze any air out and create tight bond.  My mistake was not using any release agent on bolts or 2x4.  As you can probably guess stuck pretty good.  Any advice on getting these out or did I ruin it.
March 05, 2013, 09:39:51 AM
Re: Rookie mistake
« Reply #1 on: March 05, 2013, 09:39:51 AM »
You're alright.
Get the bolts out first. One you break the seal, they should pop right out.
Spend some time on the two by's. A wrecking bar should work, just go easy.
Whatever's left,  use a grinder.
March 05, 2013, 10:16:55 AM
Group W Bench
Re: Rookie mistake
« Reply #2 on: March 05, 2013, 10:16:55 AM »
A big pry bar will break the 2x4s loose with some persuasion. You may have to grind a little remaining wood, but they will pop loose. You likely only have a bond near the bolt holes rather than the entire length of the board, so it should be quick work. Similarly, the bolts will pop if you whack them a few times with a 6 lb hammer. We commonly putty 2x6s to the shop floor with resin and cabosil to keep hulls braced and in place. When done, we pry them up with a large pry bar and they come up fairly easily.
March 05, 2013, 10:26:10 AM
pzart
Re: Rookie mistake
« Reply #3 on: March 05, 2013, 10:26:10 AM »
Quote from: "florida196"
Pictures are worth a thousand words, show those of us that haven't done a transom what your up against.
My Fat and Skinny Water Rides
My 1982 WellCraft Sportsman 248 350EFI/BravoIII
My 1975 AquaSport 170 110 Evinrude
March 05, 2013, 02:24:03 PM
florida196
Re: Rookie mistake
« Reply #4 on: March 05, 2013, 02:24:03 PM »
Here is the pics I have not the best.   What I did was cut 4 2 x 4 2 at 20 inch to run the sides one at 54 inches to cover the middle and another at 22 inches for the bottom.  Used 3/8 all thread with two different size flat washers on each side.   Drilled my holes threw the existing skin and new transom core one size larger at 7/16.   Then used about a gallon and a half can sized of cabosil mixed with over a gallon of resin plus hardner creating a thicker then peanut butter paste. Covered both new core and existing skin with putty not sparingly at all, then installed all hardware tightening  as much as I could.  Threw out the next 4 hrs, I went out every hour and was able to tighten a little more forcing what air i could out.  This is my first time ever working with fiberglass on this project.  So please correct me if any steps were wrong other than (no release agent) already learned that one the hard way
March 05, 2013, 04:29:47 PM
Re: Rookie mistake
« Reply #5 on: March 05, 2013, 04:29:47 PM »
You didn't use any cloth material between the wood core and the existing hull and the core is one piece or two?
It appears you'll get the framing and bolts off/out with a little work. 3 beer job.
OK so I like to drink. :mrgreen:
March 05, 2013, 07:51:16 PM
Re: Rookie mistake
« Reply #6 on: March 05, 2013, 07:51:16 PM »
Thanks for the pics. This is no biggee :thumright:
March 05, 2013, 09:01:09 PM
florida196
Re: Rookie mistake
« Reply #7 on: March 05, 2013, 09:01:09 PM »
Yes the sheets are two pieces of 3/4 marine ply bothe inside faces resin coated then one layer of 1708 between sheets then resin Cabosil between and set over night then back side to skin has one layer of 1708 on it
March 05, 2013, 09:50:07 PM
gman 82 aquasport
Re: Rookie mistake
« Reply #8 on: March 05, 2013, 09:50:07 PM »
Like group w bench said it's probably stuck good at the bolt holes...take the nuts off and give the bolts a decent wack with a good size hammer, if it doesn't come loose try putting a socket on the bolt head and see if you can get it to turn than hit it again...once the bolts are out try using a stiff putty knife and drive it between the 2x4's and the outer skin at the bolt holes and this should break it loose after you have pried on it at every hole...hope this helps.. this is the way I got two pieces on my floor stuck together.. :thumright:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
March 05, 2013, 11:01:15 PM
Re: Rookie mistake
« Reply #9 on: March 05, 2013, 11:01:15 PM »
Gary hit the "bolt" on the head, and taking it a step further...
Rather than bang on them....to start, twist the bolts with a socket wrench. The glue bond will break a helluva lot easier in a lateral direction....basically points of least resistance. And you won't rip material out along with the bolts.
Post up some pics when you decide to attack :wink:
March 06, 2013, 02:17:45 AM
florida196
Re: Rookie mistake
« Reply #10 on: March 06, 2013, 02:17:45 AM »
Well nothing seems to be working tried sledge impact slide hammer can't even get one to look like it wants to move.  Out of ideas
March 06, 2013, 05:32:16 AM
Callyb
  • MidWest
Re: Rookie mistake
« Reply #11 on: March 06, 2013, 05:32:16 AM »
Try putting some heat the bolts, it will soften the resin. Once you can twist them, knock 'em out. I know this works with epoxy, I am thinking it will work with poly too.
Just be careful not to set anything on fire! :|
Good luck!
Carl
___________________________
March 06, 2013, 07:05:34 AM
florida196
Re: Rookie mistake
« Reply #12 on: March 06, 2013, 07:05:34 AM »
Looks like heat is the only option left.  Just wounder if heating the bolt which will heat the epoxy resin slightly will compromise the structural integrity of the transom to skin bond or would it be Safe to go and tab the transom to inner hull before trying to remove the bolts anymore
March 06, 2013, 07:15:54 AM
Callyb
  • MidWest
Re: Rookie mistake
« Reply #13 on: March 06, 2013, 07:15:54 AM »
I will say no, but... Don't heat them to the point they are glowing or anything :!:  I would recommend to gradually raising the temp to see how hot you will need to get them.
Also, are you using polyester resin? I'm just curious to see if it works on poly also, like I said, I have never tried it with poly before.
Please let us know how it goes.
Carl
March 06, 2013, 07:41:41 AM
florida196
Re: Rookie mistake
« Reply #14 on: March 06, 2013, 07:41:41 AM »
It's epoxy resin and will post updates thanks
