22-2 Rebuilds
Miss Delmarva 1973 22-2 Rebuild Low Cholesterol Version
Topic: Miss Delmarva 1973 22-2 Rebuild Low Cholesterol Version (Read 5978 times)
March 01, 2013, 01:09:29 PM
Purgatory
Re: 1973 22-2 Rebuild
Reply #15 on:
March 01, 2013, 01:09:29 PM »
1. tube for fuel lines
2. mount for washdown pump (thanks pete!!)
3. unmounted fiberglass chase for main rigging run.
4. hole through port stringer, pvc pipe will glass inside, hose run for deck washdown outlet
5. deck mounting insert for livewell
6. bottom of cored tank hatch. dark material is permalloy for screw holding (console mounting)
The rest of the pics and those below are additional shots.
March 01, 2013, 01:11:21 PM
Purgatory
Reply #16 on:
March 01, 2013, 01:11:21 PM »
March 01, 2013, 01:13:35 PM
Purgatory
Reply #17 on:
March 01, 2013, 01:13:35 PM »
EDIT: the rubrail is from our old friends, Barbour Plastics. Off-white, their "semi-rigid" product.
Only off-white product they offer. Stainless insert stainless end caps.
March 01, 2013, 01:15:07 PM
Purgatory
Reply #18 on:
March 01, 2013, 01:15:07 PM »
EDIT: Pascoe method of tank install. Scroll back through the pics.
March 01, 2013, 01:17:22 PM
Purgatory
Reply #19 on:
March 01, 2013, 01:17:22 PM »
Here is what JD and I saw today:
The second pic is the casting platform part, showing the fishbox insulation
March 01, 2013, 01:20:38 PM
Purgatory
Reply #20 on:
March 01, 2013, 01:20:38 PM »
1973 panel true & original.
modified and powder coated Sanchez Bros top
March 01, 2013, 01:22:40 PM
Rigging Master
Reply #21 on:
March 01, 2013, 01:22:40 PM »
Those look like Innovative Lighting LED nav lights...
March 01, 2013, 01:25:21 PM
Purgatory
Reply #22 on:
March 01, 2013, 01:25:21 PM »
Bob, you are correct. They were sourced by the rigger. Painted with off-white Krylon Fusion to match the rest.
Thought it was a great idea. Off the bow, up and out of the way. No glare, and higher so more visible.
March 01, 2013, 01:32:15 PM
Purgatory
Reply #23 on:
March 01, 2013, 01:32:15 PM »
Found a couple more in the mix
Final photo ..T-Top fabric...blue-teal underneath, off-white on the top/above:
March 01, 2013, 01:35:43 PM
Purgatory
Reply #24 on:
March 01, 2013, 01:35:43 PM »
Cap almost ready for install....wish the gelcoat color showed better
March 01, 2013, 01:40:04 PM
Purgatory
Reply #25 on:
March 01, 2013, 01:40:04 PM »
Since you inquired about the Adeptus 22-2 316 stainless badge....here it is, correct size and width per factory spec.
This is the first AS badge of original dimension that they have produced:
They have it on file, under my name. Anyone so inclined, feel free to give them a call, and reference your membership here.
New Morse controls, for twin outboards:
Perko chrome on bronze hawse pipe, one per side at the stern: Made in USA.
You guys remember the plating place in Miami....link is on Resources....here is one of the rodholders they re-plated:
SB's quality UW light in blue...optional buff color:
March 01, 2013, 01:49:23 PM
Purgatory
Reply #26 on:
March 01, 2013, 01:49:23 PM »
Poor photo quality "quickie mold" to fab fiberglass hatches
block foam installed, ready for floor
tank hatch, top
tank hatch, underneath
underneath shot of casting deck, insulation for fishbox
melamine forms for interior stern hatches
March 01, 2013, 07:48:16 PM
Purgatory
Reply #27 on:
March 01, 2013, 07:48:16 PM »
Floor is in. Took 5 gallons of adhesive. It is STIFF.
Interior hullside foam core will be glassed-in next....finished, then gelled. Should end up just like a liner, but stronger. The builder says it will also deaden the sound of hull slap.
March 01, 2013, 07:55:04 PM
Purgatory
Reply #28 on:
March 01, 2013, 07:55:04 PM »
Last few days....core on the inner hull sides installed and glassed. Fairing on the floor. Inside transom boxes.
This pic shows a duralloy deck brace and the hull-side coring
Floor hatch forward of console, life jacket storage
March 02, 2013, 07:36:49 AM
Purgatory
Reply #29 on:
March 02, 2013, 07:36:49 AM »
Pics from yesterday, fairing in the cored sides to the floor:
This last pic shows the divinycell coring pretty well
22-2 Rebuilds
