1. How many gallons is that tank, looks huge2. How do you plan on running the plumbing for the livewell?3. What are those yellow things on the gunwales? Im guessing Floor support, but they appear higher than the stringers Looking great, do u think she'll be ready by summer?
Scott, the glass work is excellent!! Couple suggestions on the top and console. You're going to have an e-box, right? Have them cut 1" holes in the aft legs, then weld short legs going to the sides of the top for wire entry. A whole lot cleaner than just a hole out of the leg, a hole in the ebox, then covered with spit-loom.Second, nothing wrong with attaching the aft legs to the console, but that area has to be beefed up substantially. The reason that earlier model 225/245 Ospreys went from that type of design to a top design where all 4 legs t/bolted to the deck was stress cracking around the aft leg mounting flanges. Core that area at least 12" X 12" to spread the load, and no foam, it needs to resist compression. Coosa would be a good choice...She's looking good!!!
