Author Topic: Parts for OMCs JOHNSON,Evenruide, Mercury , Force outboards  (Read 1592 times)
February 27, 2013, 01:10:32 PM
Read 1592 times
WICKEDGOOD
« on: February 27, 2013, 01:10:32 PM »
Some are New Some are fresh water USED.
Will sell individually or Make me an offer for the whole lot
Outboard Motor Parts for OMCs JOHNSON 60,70,85,90,100,110,115,130,150 hp outboards. And others
90 Degree loopcharged years 1985 thru 1998
Email Me at Capt@WickedGoodOutdoors.com
Current List as of 10/01/2012
QTY DESCRIPTION New/Used Price Ea. Extended Price
 1 Teleflex SeaStar steering Hydraulic Helm Tel Part# HA5418. New $399 $399
3 "Water Pump Impeller Teleflex 18-3056 Impeller - Dia. 3 1/2"",Dpth. 1 1/4"" - 6 Fins - Neoprene
Honda # 06192-ZW1-00 Fits Honda 75HP and Mercs 4743026-2 and others.
 " New $15 $45
4 Johnson/Evinrude New Stainless Steel Steering arms for outboards ( Will fit other brands) New $75 $300
1 Johnson/Evinrude Alum Propeller, NEW, 14 X 19 #176215, 13 splines fits Johnson/Evenrude New $95 $95
1 Johnson/Evinrude Tilt Pins retainer Bars for Johnson/Evinrudes ( Will fit other brands) New $20
2 Johnson/Evinrude VRO hose & Pump & Sender New $100 $200
1 Johnson/EvinrudeTRIM TAB 327640 OMC New $20
1 Johnson/EvinrudeVRO Kit Part # 438406 includes Pump #175161 New $250
1 Johnson/Evinrude Zinc Skeg trim tab New $20 $20
1 Johnson/Evinrude drive shaft New $100 $100
3 Johnson/Evinrude #323664 Spline Gear New $99 $297
3 Helical Lower unit Gear sets 340490 New $100 $300
1 Johnson/Evinrude New Rectifier/Regulator Kit #CD4 583110 9GR-0A New $150
1 Johnson/Evinrude New Rectifier/Regulator Kit # 395391 New $150
1 Johnson/Evinrude Ignition Coil Kit # 583737 New $99 $99.00
2 Johnson/Evinrude Ignition coils #582508-0560-0A New $25 $50.00
2 Johnson/Evinrude POWER PACKS OMC CD4 584027 New $85 $170
1 Johnson/Evinrude Voltage Regulator Kit # 173640 New $179
2 Johnson/Evinrude Timer Base Kit #583376 New $150
1 Johnson/Evinrude wiring electrical harness for controls to engine with big red plugs New $80
1 Johnson/Evinrude Water Pump Impellers for 85-150 HP New $15
1 Johnson/Evinrude Complete Water Pump kit for ? HP #391391 New $50
1 Johnson/Evinrude CompleteWater Pump kit for 85-150 HP Part # New $50
2 Johnson/Evinrude Evinrude Johnson 3" Tach & System Check Gauge. New $140 $280
2 Johnson/Evinrude Trim Indicator Gages New $50 $100
1 Johnson/Evinrude lower unit Gasket #286279-2 New $20
1 Johnson/Evinrude Complete Gasket set #139300 fit 85 to 150 HP V4 motors New $50
2 Johnson/Evinrude Rubber Exhaust Gaskets fit 85 to 150 HP V4 motors New $10 $20
6 Johnson/Evinrude Gaskets # 317914 fit 85 to 150 HP V4 motors New $6 $36
1 Johnson/Evinrude Gasket # 359-317955-1 New $8
9 Johnson/Evinrude Gaskets # 194-321727-1 New $8 $72
1 Johnson/Evinrude Gasket # 436-323459-1 New $8
5 Johnson/Evinrude Gasket # ???? New $6 $30
1 Johnson/Evinrude drive shaft 85 to 150HP New $100
1 Johnson/Evinrude Clutch dog OEM #22683 OEM #319895 New $100
 2 Johnson/Evinrude Helical Lower unit Gear sets # 340490 New $199 $398
4 Johnson/Evinrude 90HP-150HP Rod Bearings set New $50 $200
10 Brand New Valves for Inflateable Boats. New $25 $250
1 CMC electric trim gage New $50
1 CMC. PT-130 Transom Clamp Motor Adapter (#13022) New $50
2 Aqua Power Impeller JP 28948-001OMC #509182 Fits Jabsco Seawater Used $20 $40
Teleflex 18-3056 Impeller Dia. 3 1/2"",Dpth. 1 1/4"" 6 Fins NeopreFits Honda 75 to 150 and Mercs and others.New $17 $51 Used $25
3 #323664 Spline Gear $99.ea. New $99 $297
1 Ignition Coil Kit # 583737 New $99 $99
1 Voltage Regulator Kit # 173640 New $189
2 Helical Lower unit Gear sets 340490 New $199
2 Rubber Exhaust Gaskets New $10 $20
1 Complete 90 Hp Gasket set # 139300 New $50
1 Gaskets # 317914 New $6
2 "used OMC Stator #583669, #583672,
" New $50 $100
2 "used JOHNSON/ Evinrude Stator #583669, #583672,
" New $40 $80
1 Johnson/Evinrude Zinc TRIM TAB 327640 New $20
2 Johnson/Evinrude fuel fitings New $8 $16
1 Johnson/Evinrude set of new plastic engine throttle connector slides New $20 $20
1 Johnson/Evinrude VRO Oil Tank with hose & Pump & Sender New $100 $100
1 Fuel Fittings Set male & Female old style Merc New $15 $100
1 Fuel Fitting Honda New $10
1 Fuel Fitting Suuzki New $10
Teleflex throttle/shift CABLES OMC Johnson/Evinrude NEW! Just $2 per foot. New
2 Teleflex Black 12ft t shift/throttle cable OMC New $15 $30
1 Teleflex Black 15ft t shift/throttle cable OMC, Johnson/Evinrude New $20 $40
3 Teleflex Black 12ft t shift/throttle cable Merc/Mariner New $17 $32
3 Teleflex Black 16ft t shift/throttle cable Merc/Mariner New $25 $75
New
Teleflex Black throttle/shift CABLES New
1 Teleflex Black 23 ft shift/throttle cable MERC New $32
1 Teleflex Black plastic steering wheel New $15
1 remote steering Alum Bracket for the Merc/Force 9.9 or 15HP outboard motor. ( May fit other brands) New $40
1 Plastic Pitot Tube pickup New $5
2 Battery Rotary Switchs USED $20 $40 Used
1 pair of Standard Battery to Engine Cables Used $25
2 Johnson/Evinrude electric fuel chokes Used $25 $50
1 Johnson/Evinrude 90 hp Carburator Used $50
1 Timer Base Kit #583376 Used $100 $100
1 Johnson/Evinrude Rectifier Blue Power pack no part # Used $85
1 Johnson/Evinrude Rectifier/Regulator # CD4 #583336 23IM-0A Black Rectangle Used $100
1 Johnson/Evinrude Rectifier/Regulator #5114-04 DT-4 G Alum Metal Rectangle 3 wires? Used $50
1 Johnson/Evinrude Rectifier/Regulator # 395391 Used $85
1 Johnson/Evinrude pt/pt Relay Box with Cable Used $50
1 Recoil Starter Assembly for Merc/Force 9.9 or 15HP outboard motor. Used $50
1 factory service manualfor Merc/Force 9.9 or 15HP outboard motor. Used $40
4 Tilt Pins retainer Bars for Johnson/Evinrudes Used $20 $80
2 Stainless Steel Steering arms for outboards Used $40 $80
2 Stainless Steel Steering Coupler brackets Used $40 $80
2 Johnson/Evinrude Ignition coils #582508-0560-0A Used $99
1 Johnson/Evinrude OMC Stator #583672 Used $75
1 Johnson/Evinrude OMC Stator #583669, Used $75
4 Johnson/Evinrude ignition coils Used $10 $20
2 Johnson/Evinrude Flywheel Used $100 $200
1 Johnson/Evinrud Shift/Throttle control Housing $40 Used $40 $40
1 Johnson/Evinrude Plastic Fuel Tanks Used $20 $20
3 Johnson/Evinrude TRIM TAB (adjusts outboard torque) 327640 Used $20 $60
1 Johnson/Evinrude throttle/shift control Used $50 $50
1 Johnson/Evinrude throttle/shift control, missing a few parts Used $25
4 Johnson/Evinrude Big heavy Alum wedge Motor Mounting Brackets to shim up outboard on transom Used $40 $120
1 Johnson/Evinrude plastic throttle shift handle with pt/pt switch Used $20
1 Johnson/Evinrude plastic throttle handle. Used $15
1 Johnson/Evinrude complete wiring electrical harness with lots of electrical parts from Johnson 90HP V 4 Used $100
2 Johnson/Evinrude wiring electrical harness for controls to engine with big red plugs Used $50 $100
2 Johnson/Evinrude Tachometer used Used $10 $20
1 LOWRANCE Blue water Pro Flasher/Paper chart recorder Fishfinder with transducer. Used $150
1 RAYNAV 520 Loran with coupler Used $50 $50
1 Apelco handheld GPS 15 with dashboard mounting bracket Used $100 $100
1 Raytheon VHF/TV Anttena Dome Used $40 $40
2 High Flyer RADAR Bouys Used $40 $80
1 ONAN Temp Gage #129-8739 desc: AK21LB23 New $150
1 ONAN Temp Sender #7E-4279 desc: AK 25EB33 New $100
1 Adaptor # 9M-6522 Desc: FITAM26 New $6
1 TEE # 033-2177 Desc: FITDP08 New $40
1 ONAN Fuel/Oil Filter New $10
Used
4 Factory & Aftermarket Marine Outboard Motor Repair Manuals Johnson, Mercury, Force, Subaru Used $10 $40
1 pair Large indoor/Outdoor waterproof speakers used Used $40 $40
1 pairSmall indoor/Outdoor waterproof speakers used Used $40 $40
Used
2 Two Power tilt motors for older OMC I/O outdrive. Unknown condition need rebuild. Used $20 $40
1 Bronze 11/2 Prop Nut Used $5 $5
Used
1 Fuel Hose with Fuel Fittings & Primer old style Merc Used $10 $10
1 Fuel Fittings Set male & Female old style Merc Used $10 $10
1 Johnson/Evinrude Fuel Hose with Fuel Fittings & Primer Used $5 $5
Teleflex throttle/shift CABLES OMC Johnson/Evinrude USED Just $1 per foot. Used
4 Teleflex Black 12ft t shift/throttle cable Merc/Mariner Used $12 $48
4 Teleflex Black 12ft t shift/throttle cable Merc/Mariner NEW $24 $96
4 Teleflex Black 16ft t shift/throttle cable Merc/Mariner NEW $32 $128
1 Teleflex Black 23ft t shift/throttle cable Merc/Mariner New $46 $46
1 pair of Alum/Plastic oars for inflateable boat Used $20 $20
2 Child class 3 life preservers Used $4 $8
4 Class I Life Preservers Used $25 $100
1 30 inch USCG Approved Orange life ring Used $45
1 Teleflex Marine Trident Blue Wet Exhaust Hose 3 dia X 50 lg. Used $50
20 Heavy Battery Cables 2 ft long with ring lugs Just $5. per foot Used $10 $200
1 Raytheon Marine Electronics Factory Service Marine set of 2 Used $40
1 Transom Clamp Motor Adapter CMC (#13022) Used $50
2 Alum Dingy Davit Brackets NEW $200
