Author Topic: Question about drain on 1995 225 Explorer  (Read 826 times)
February 28, 2013, 06:15:06 PM
Re: Question about drain on 1995 225 Explorer
« Reply #15 on: February 28, 2013, 06:15:06 PM »
Quote from: "wingtime"
I'm wondering how the fitting managed to get broken in the first place!  I'm betting they connected the hose to the box drain at the factory before they put the cap on.  Then they connect it to the thru hull fitting thru the pie plate at the aft end of the walk around.
I was wondering the same myself, and Bruce I think your right, but on mine it would be possible to get to it from the forward pie in the floor if you could connect the hose and put on the clamps with one hand  :shock: oh and get around the gas tank
February 28, 2013, 06:26:32 PM
« Reply #16 on: February 28, 2013, 06:26:32 PM »
I don't think I can reach the drains by going thru the forward pie over the fuel tank. I think the stringer is in the way.  Butof course I've never tried.
February 28, 2013, 09:30:25 PM
« Reply #17 on: February 28, 2013, 09:30:25 PM »
I had my arm in mine once when I rewired my fuel sender to the dash, not very fond memories of it.
