I'm pretty sure you can expect HP/10 = WOT fuel burn. Doesn't seem to matter 2 or 4 Stroke unless the hull is really special, which the Explorers are not.
I would be curious in these #'s also but full throttle all these motors are the the same, it's low and mid rpm range were the 4's shine.
Which 200 yamaha are you running Delta and which prop?
