If your boat does not have flo-scan gauge I'd highly recommend you buy one since it will quickly pay for itself in fuel savings and it's much cheaper than a repower!
Fitz, you got me, it's usually Bob And me Posting at the same time... I guess we were on the same page anyway
The meter doesn't save fuel...a prudent captain does.
Quote from: "gran398"The meter doesn't save fuel...a prudent captain does.True but when you throw engine tilt and trim tabs into the mix you won't be nearly as accurate without it
Quote from: "Circle Hooked"Quote from: "gran398"The meter doesn't save fuel...a prudent captain does.True but when you throw engine tilt and trim tabs into the mix you won't be nearly as accurate without it You're right. And right back to the teaching tool idea. Once you've hit the sweet spot on your ride...and know the sweet spot...it's pretty much a done deal.
