Author Topic: What would be considered a skiff?  (Read 1216 times)
February 19, 2013, 12:10:09 AM
Read 1216 times
126andy
    • http://www.afteryoufishing.com
« on: February 19, 2013, 12:10:09 AM »
I was just wondering what would be classified a skiff. I have a 1997 Aquasport striper 165. Would that be considered a skiff? I seen lots of people calling boats skiffs but I don't really know what makes them a skiff. I guessing that it is a semi flat bottom boat with no draft to speak of. I a boat has a gas tank below the deck instead of an external can does that make it not a skiff?
My short-term memory is not as sharp as it used to be.
Also, my short-term memory\'s not as sharp as it used to be.
February 19, 2013, 12:20:18 AM
Re: What would be considered a skiff?
« Reply #1 on: February 19, 2013, 12:20:18 AM »
Skiff would have supper low gunnels and a very shallow draft 6-8" and usually in the 14-18 ft range, and be set up for push polling, Andy your boat is very close, I would consider it a skiff more then anything else and that's not a bad thing.
February 19, 2013, 12:36:24 AM
« Reply #2 on: February 19, 2013, 12:36:24 AM »
I thought a "skiff was more of a small boat like 10 to 12 ft like a jon boat with a small kicker,Andys' would be called a "flats boat" by todays' definition....or not,maybe a skiff is in the eye of the captain. :scratch:
February 19, 2013, 02:55:30 PM
« Reply #3 on: February 19, 2013, 02:55:30 PM »
Well then you have Micro Skiffs or Technical Polling Skiffs also  :?
Biggest of all is the word Skiff adds $ to the price tag which is why the widespread use of the word.
February 19, 2013, 03:15:21 PM
« Reply #4 on: February 19, 2013, 03:15:21 PM »
I think skiff is one of those names that is used to describe many different types of boats depending on use, region, etc etc.  Ever hear of a captains skiff?  Skiff is even used to describe a certain types of small sail boats and so on.  I think generally the traditional term describes a small flat bottomed boat with shallow draft powered by oars.  In our recreational fishing world I think marketing has applied the name to a bunch of small boats but I would say a boat with shallow draft and a flat bottom could be called a skiff.
February 19, 2013, 04:11:37 PM
« Reply #5 on: February 19, 2013, 04:11:37 PM »
A skiff is, by definition, a shallow, flat-bottomed open boat with sharp bow and square stern.  A flatback could be considered a skiff, but the semi-v and deep-v Aquasports are not really skiffs.  Neither are most Carolina Skiffs, cuz they ain't got no sharp bow!  But that's OK, cuz they are not made in Carolina either!  I guess today you can call a boat about anything and somebody will buy it.
February 19, 2013, 09:13:29 PM
« Reply #6 on: February 19, 2013, 09:13:29 PM »
Remember CJ, if you catch a bass fishing from a jon boat, said jon boat can now be called a bass boat!  And will fetch a premium price!
February 20, 2013, 06:54:47 AM
« Reply #7 on: February 20, 2013, 06:54:47 AM »
just like said jon boat fishes the flats, it magically becomes a flats boat
http://tampa.craigslist.org/hil/boa/3620530017.html
February 20, 2013, 10:59:30 AM
126andy
« Reply #8 on: February 20, 2013, 10:59:30 AM »
Quote from: "Aswaff400"
That guy covered all his bases, he called it a flats boat in the title and a Bass boat in the ad.
February 20, 2013, 01:30:25 PM
« Reply #9 on: February 20, 2013, 01:30:25 PM »
I've seen some ads in the past for 80's model tri hull boats and they were called flats skiffs  :scratch:
February 20, 2013, 05:33:50 PM
MarshMarlowe196
« Reply #10 on: February 20, 2013, 05:33:50 PM »
The definition I found for "Skiff" on boats.com reads, simply:
"A small, simple, shallow-draft boat."
So what's simple?  Well, the rough unfinished interior (no inner liner) of a boat like a Carolina Skiff with few hatches and little to no bells and whistles is about as simple as it gets.  I think the Striper is of a better fit and finish with an inner liner, with a better layout than a conventional skiff.  To add to this, I believe a Jon Boat is basically the name for an Aluminum Skiff.
"Flats boat" definition from the same source:
"Type of small, inshore saltwater fishing boat with moderate deadrise and draft, usually equipped with a raised platform aft used by a guide pushing a long pole to silently maneuver the boat through shallow tidal water. "
Seems like any boat that could be referred to as a Flats Boat would at least have to have a stock poling platform to get away with the designation.
A "Bay Boat" is what I would classify the Striper as, minus the rolled edge-
"Low-profile, inshore fishing boat intended for use in protected coastal waters, and frequently made with rolled-edge construction."
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
