Author Topic: Flatback Fireboat Rebuild  (Read 32568 times)
July 02, 2014, 09:46:31 PM
Reply #345
Re: Flatback Fireboat Rebuild
« Reply #345 on: July 02, 2014, 09:46:31 PM »
this time next week ill be in DFW cooking my a$$ off. last summer it was 104 degrees with a heat index of 115-120 for 5 of the 7 days
i havent got much done in the last 2 weeks on my flat back. even inside with the fan blowing its hard to get anything done... i gave in and called one of our fiberglass guys to come finish the inside of the boat.
July 02, 2014, 11:23:13 PM
Reply #346
« Reply #346 on: July 02, 2014, 11:23:13 PM »
Quote from: "Aswaff400"
NOOOOOOO!  Just kidding!  I don't blame you one bit :salut:
July 03, 2014, 09:33:54 AM
Reply #347
redemn93
« Reply #347 on: July 03, 2014, 09:33:54 AM »
what are you cooking?  bbq?
July 03, 2014, 09:38:06 AM
Reply #348
« Reply #348 on: July 03, 2014, 09:38:06 AM »
Quote from: "redemn93"
I think himself
July 03, 2014, 11:10:19 AM
Reply #349
redemn93
« Reply #349 on: July 03, 2014, 11:10:19 AM »
oh.  i guess im hungry.
July 03, 2014, 05:39:59 PM
Reply #350
« Reply #350 on: July 03, 2014, 05:39:59 PM »
there will be a bbq though! lol
July 11, 2014, 11:10:16 PM
Reply #351
« Reply #351 on: July 11, 2014, 11:10:16 PM »
Not much progress to report, but a question about bulkheads...I am using nidacore for my bulkheads.  Eugene recommended 1" thick material.  I don't have any 1", but I've got some excess 1/2".  So I made a sandwich (1808, 1/2" nidacore, 2 x 3/4 oz mat, 1/2" nidacore, 1808).  Do you think that is adequate, or should I add another layer of 1808 on each side?
July 12, 2014, 06:30:40 AM
Reply #352
« Reply #352 on: July 12, 2014, 06:30:40 AM »
When you tab them in you'll get a couple more layers on each side  :salut:
July 12, 2014, 08:33:56 AM
Reply #353
« Reply #353 on: July 12, 2014, 08:33:56 AM »
Good point Rick :thumright:
July 12, 2014, 08:21:22 PM
Reply #354
Aquasport Commodore
« Reply #354 on: July 12, 2014, 08:21:22 PM »
Instead of using the Nida for bulkheads, why not do it like your stringers and how they do newer boats. Foam bulkheads covered glass? This way you can go as wide as you want with no issues.
July 12, 2014, 10:07:28 PM
Reply #355
« Reply #355 on: July 12, 2014, 10:07:28 PM »
Quote from: "86Aqua"
I'm sure that would work, and have the benefit of extra surface area to bond with the deck.  But they would be a bit more work and money than the nidacore.  I'm getting to the point of trying to simplify things to give the perception of making progress, while using up the supplies that I have stockpiled over the last year and a half.
August 19, 2014, 11:16:00 AM
Reply #356
« Reply #356 on: August 19, 2014, 11:16:00 AM »
Craig, had another idea re the livewell viewing port. How about making a fiberglass part like a recessed picture frame....that would dress it up real nice from the outside. Little starboard trim, good to go :thumright:
August 24, 2014, 09:19:54 AM
Reply #357
« Reply #357 on: August 24, 2014, 09:19:54 AM »
Well, I have been chipping away at it.  I am finally close to putting the deck on.  I've got the stringers done, as well as the bulkheads and rigging tubes.
I added a ledger to help support the perimeter of the deck.  If you read a lot of Scotty's (aka Gran398) posts, you will see this mentioned several times.  Many feel it is unnecessary, and they may be right, but I feel better knowing there is extra support under the edge and I'm not just relying on the stiffness of the deck and the tabbing on top to keep the joint from flexing and developing cracks in the gel.  And it can't hurt, right?
This pic gives you a pretty good view of the ledger, as well as the rigging tubes for the fuel fill line (front tube), vent line (right behind the fuel line tube), and fuel line to the engine (back tube that suns along the port side of the boat).  Note that I still have some trimming to do to level the top of some of the bulkheads.
Here is another view of the fuel line rigging tubes.  The 2 tubes in the front run from the console and bilge area, inside the stringers, up to the bow area.  They will be used for lights, speakers, and maybe even battery cables if I need to move the batteries forward for weight distribution..
Next I need to do some prettying up of the glass in the bilge area and some other spaces to get it ready for paint.  Still need to decide on what bilge paint to use.  I've got a combination of poly and epoxy, so I need something compatible with both.  Suggestions?
August 24, 2014, 10:23:00 AM
Reply #358
« Reply #358 on: August 24, 2014, 10:23:00 AM »
She looks GREAT!!  Glad you added the ledger strips. Gonna tie everything together like a rock.
Are the ledgers solid glass, appear to be :thumright:
August 24, 2014, 12:47:59 PM
Reply #359
« Reply #359 on: August 24, 2014, 12:47:59 PM »
They are, Scotty.  The ledge is 3/4 oz mat and 3 layers of 1808.  I took a piece of plywood that was just shorter than the distance between the bulkheads and cut one edge to match the contour of the hull.  I added supports that spanned the bulkheads, along with spacers that dropped the plywood to about 1/4" below the top of the bulkheads.  This gave me a shelf that would sit slightly recessed between the bulkheads.  I glassed the mat and two 5" wide strips of 1808 to the hull, between a pair of bulkheads, so that about 1.5" of the strips were above stringers and about 3.5" were below them.  Then I put the shelf in place and folded the top 1.5" over onto the shelf (I used duct tape on the wood to keep the resin from bonding to it).  Then I tabbed a 2.5" strip of 1808 to the top of the ledge and about 1" up the hull.  (I chose 1" because I wanted to keep the upper edge below the top of the deck so that it doesn't add the to thickness when I tab in the deck).
After I finished with each section, I moved the wooden shelf to the next section and cut the edge of the plywood to match the contour and repeated the glassing.
I don't know if my description makes sense, but it worked out pretty well and the ledgers are quite sturdy :thumleft: .
