Silly questions for those of you that have tabbed in your existing stringers...how did you go about doing it? Did you run continuous strips of glass along the entire hull/stringer joint? Or did you just do intermittent "tabs".Also, tabbing in these trapezoid stringers requires glassing the underside of the angled stringers. Does this create a problem with the glass wanting to fall down? If so, is there a trick to keep it in place until it cures?Lastly, a question on pourable foam...how much do you mix at a time?Thanks!
