Plumbing
Through hull or Seacock
Topic: Through hull or Seacock (Read 851 times)
January 28, 2013, 12:15:44 PM
Read 851 times
Thepipebender
January 28, 2013, 12:15:44 PM »
I want to put a raw water wash down pump on my boat. What's the better way to go?where should I mount this?Through the transom? Through the floor? Should I use a through hull or sea cock type fitting?
January 28, 2013, 12:52:45 PM
Re: Trough hull or Seacock
January 28, 2013, 12:52:45 PM »
Both, install the thru hull thru the bottom of the boat then the seacock on top of the thru hull.
January 28, 2013, 07:38:52 PM
Re: Through hull or Seacock
January 28, 2013, 07:38:52 PM »
^^ Ditto.
January 28, 2013, 07:48:18 PM
Rigging Master
January 28, 2013, 07:48:18 PM »
Double ditto...
Through the hull bottom, simple bronze mushroom head t/hull, standard threads. If you think you might plumb it to a livewell, go with a scoop strainer t/hull...
Either way, install a strainer inline before the pump to keep the grass out of the pump...
January 29, 2013, 11:24:26 AM
Thepipebender
January 29, 2013, 11:24:26 AM »
Sounds great!Any special distance from the transom, perticular spot?
January 29, 2013, 11:30:58 AM
January 29, 2013, 11:30:58 AM »
Place it offset from the prop/lower unit. You don't want it disturbing the water flow to the prop or water intake on the lower unit. Also, place it where it is easily accessible in the event you are taking on water and you need to shut the seacock.
January 29, 2013, 12:19:12 PM
bondobill
West Coast
January 29, 2013, 12:19:12 PM »
Replaced mine last summer.
offset about a foot give or take a few inches from center of keel
Easy access thru hatch at stern.
Bill
1979 222 FF
- Winston Churchill
Bill
January 29, 2013, 08:38:45 PM
Thepipebender
January 29, 2013, 08:38:45 PM »
Great thanks!
Plumbing
