Author Topic: Deck hatch  (Read 1069 times)
January 15, 2013, 07:11:16 PM
Read 1069 times
pigbike
Deck hatch
« on: January 15, 2013, 07:11:16 PM »
I need to replace my rear deck hatch which is cracked. It is made by So-Pac and is model # 30155. It seems that no one has these anymore, or at least I can't find one. Anyone know of a vendor who might have one. I could use another brand but I don't know what the opening size is and can't take this one off as all the screw holes are plugged. I don't want to drill out the plugs and find that there are no replacements in that size.
Roy
January 15, 2013, 07:14:21 PM
Re: Deck hatch
« Reply #1 on: January 15, 2013, 07:14:21 PM »
I have a new hatch 22 X 16 if that will work.
January 15, 2013, 07:21:05 PM
pigbike
Re: Deck hatch
« Reply #2 on: January 15, 2013, 07:21:05 PM »
That is too big. Looks like outside measurments are 12 7/8" x 15 3/4.
January 15, 2013, 09:21:38 PM
Mulv80
Re: Deck hatch
« Reply #3 on: January 15, 2013, 09:21:38 PM »
Their new 4000 series hatches are pretty close in dimension, 13-1/8 x 15-1/2 .  Google SPA-40155, "SOPAC" is now "Imtra".
99\' Aquasport 215 DC, Johnson 200 Ocean Pro
January 15, 2013, 10:17:29 PM
pigbike
Re: Deck hatch
« Reply #4 on: January 15, 2013, 10:17:29 PM »
Quote from: "Mulv80"
I would be afraid that it might not fit the opening properly, and wouldn't know unless I had the hatch in hand. If it didn't fit I would have to return it and that is a pita. I might see what West Marine has in stock.
January 15, 2013, 10:21:34 PM
Re: Deck hatch
« Reply #5 on: January 15, 2013, 10:21:34 PM »
How much room do you have? Can you expand the cutout?
Bigger is better...makes it easier to get your head/arm in there to work.
Don't be pigeonholed by original dimensions...go with ease of use if possible.
January 16, 2013, 07:28:18 AM
pigbike
Re: Deck hatch
« Reply #6 on: January 16, 2013, 07:28:18 AM »
I would have to look at it a little closer. I think the deck is recessed so that the outside ring of the hatch is level with the floor. I could be wrong, so I will have to check it. I don't really want to start cutting up the deck however. I just need one that will fit the existing cutout.
