MAN OH MAN!!!!She is absolutely beautiful JD He just did a whiz-bang job on everything. The way he matched the deck, the gelcoat, the drains, everything I'm thinking some standup rodholders on the backside of the splashwell would be cool
The only thing I am struggling with is the placement of the trim tab control box. I was thinking in the bilge mounted high up the stringer I have plenty of room that is for sure.
Quote from: "jdupree"The only thing I am struggling with is the placement of the trim tab control box. I was thinking in the bilge mounted high up the stringer I have plenty of room that is for sure.I've been trying to figure out the same thing. What do you have behind those round inspection ports on the port side stern area. That's where I was planning to install mine. If you install it on the inside of the forward facing bulkhead you could unscrew that inspection cover and just look in there to inspect it for leaks/level pretty easily. Also, it would be high and dry, out of the bilge. I'll be interested in what you decide because my set up has little to no storage or extra space.
Quote from: "gran398"MAN OH MAN!!!!She is absolutely beautiful JD He just did a whiz-bang job on everything. The way he matched the deck, the gelcoat, the drains, everything I'm thinking some standup rodholders on the backside of the splashwell would be cool Thanks Scott Vertical rodholders sound good. Show me what you had in mind.Thanks to everyone for the compliments. It is much appreciated.Want to give a special thanks to Bondobill He gave his time to send me several emails, pictures, measurements, etc. I think Bill came up with the best design for anyone that battles the worthless splashwell I don't feel like cockpit security has been compromised, and I gained close to 2 feet of additional deck space and bilge access. Thanks again Bill The only thing I am struggling with is the placement of the trim tab control box. I was thinking in the bilge mounted high up the stringer I have plenty of room that is for sure.
Wow, she looks great! You practically have a new boat, and no more Poggie Slime Clogged drains. It looks fantastic and I know your thrilled. Get her rigged up, cauz spring is here (atleast in FL) and get the family out on the water and enjoy the NEW open space. WooooooooooWeeeeeeeeee :king: Congrats bro.
Quote from: "jdupree"The only thing I am struggling with is the placement of the trim tab control box. I was thinking in the bilge mounted high up the stringer I have plenty of room that is for sure.Dan - I must have an older control box but mine will not fit thru those pie plates. I had it mounted in the splashwell before I removed it. Not sure where I will put it, but I will sure let you know. Thanks for the interest Quote from: "gman 82 aquasport"Looks great JD, I know your glad that you did it..does look like a new one.
Quote from: "Curious"Quote from: "jdupree"The only thing I am struggling with is the placement of the trim tab control box. I was thinking in the bilge mounted high up the stringer I have plenty of room that is for sure.I've been trying to figure out the same thing. What do you have behind those round inspection ports on the port side stern area. That's where I was planning to install mine. If you install it on the inside of the forward facing bulkhead you could unscrew that inspection cover and just look in there to inspect it for leaks/level pretty easily. Also, it would be high and dry, out of the bilge. I'll be interested in what you decide because my set up has little to no storage or extra space.On my CCP, I mounted the pump in the center console, on top of the tackle storage box on the port side.
Bob - That location would be ideal, but my hoses coming off the box are short. I guess that I could get more hose, but then I would have to run them back there I will see how my body holds up once I get everything else done. Thanks for the suggestion
Quote from: "jdupree"Bob - That location would be ideal, but my hoses coming off the box are short. I guess that I could get more hose, but then I would have to run them back there I will see how my body holds up once I get everything else done. Thanks for the suggestion I started with the full length hoses back then and had all the rigging pulled out so it wasn't that bad, still.....When I remounted the unit on my WAC I "thought" about mounting it up by the helm but then I "woke up". It now resides in the stern port side, where one of the batteries was located. Very easy to access, though it required little maintenance while under the console.There is indeed a lot of room down below and now you have access. In the 80s you and I could have done a lot of business in the Keys. :pirat: Good luck JD
