Author Topic: Good AC/DC meter for the price  (Read 446 times)
January 02, 2013, 11:57:51 AM
Read 446 times
« on: January 02, 2013, 11:57:51 AM »
Uni-T model UT203 - good meter to keep on the boat - does AC and DC amps/volts/frequency/duty cycle, etc.  Made in China, but what isn't these days?
http://www.ebay.com/sch/i.html?_trksid= ... &_from=R40
January 04, 2013, 01:20:55 PM
daniel123
Re: Good AC/DC meter for the price
« Reply #1 on: January 04, 2013, 01:20:55 PM »
What are the apps? I'm a electrical system Luddite but willing to learn -- and if one of these makes it easier to diagnose trouble...For example, does the ring feature allow you to see if power is going through an encircled wire? (I told you I was dense in current matters)
January 04, 2013, 06:03:32 PM
« Reply #2 on: January 04, 2013, 06:03:32 PM »
Quote from: "daniel123"
Yes,
If you have enough current going through said wire. I wouldn't think you would use it too often in that application, though you could measure your current draw to the starter while under load. :idea:
Mo better for wire troubleshooting of grounds and power connections (voltage and resistance/ohms). Handy and useful when you get the knack. Not too steep a learning curve with a little time. Good price for a committed boat tool. Pays for itself after a couple of uses. Works on your vehicle and around the house.  :idea: The clamp is more useful in the AC current mode (IMHO) but I did use mine to measure DC current at the starter for cable sizing. :thumleft:
