Author Topic: fuel tank fabrication  (Read 1099 times)
December 25, 2012, 06:33:31 AM
Read 1099 times
Thepipebender
« on: December 25, 2012, 06:33:31 AM »
December 25, 2012, 06:39:33 AM
Thepipebender
Re: fuel tank fabrication
« Reply #1 on: December 25, 2012, 06:39:33 AM »
After fabrication I pressure tested  tank and installed.
December 25, 2012, 06:43:33 AM
Thepipebender
« Reply #2 on: December 25, 2012, 06:43:33 AM »
Anoyher pic mounted and installed.
December 25, 2012, 07:07:38 AM
« Reply #3 on: December 25, 2012, 07:07:38 AM »
:thumleft:
December 25, 2012, 02:46:48 PM
dburr
« Reply #4 on: December 25, 2012, 02:46:48 PM »
One of the high rate failures is stripped threads and leaking around the sender mount over time.  Since you built the tank would it be feasible to put a boss around the sender hole to double the thickness for greater thread depth? It would be less likely for you to have stripping issues should the sender ever have to come out/go in again...   :scratch:
REALLY nice looking tank!!!! :cheers:   :salut:
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
December 26, 2012, 08:00:21 PM
gman 82 aquasport
« Reply #5 on: December 26, 2012, 08:00:21 PM »
X2 what dburr said, you want more thickness where the sender will be screwed down :thumright:
Are you going to foam it in or use wood blocks to keep it from moving?
Nice looking tank!
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
December 26, 2012, 08:04:59 PM
« Reply #6 on: December 26, 2012, 08:04:59 PM »
X3....Now would be the time to add the extra, and complete the heat :salut:
Nice work...digging the baffle :thumright:
December 27, 2012, 05:22:54 AM
Thepipebender
« Reply #7 on: December 27, 2012, 05:22:54 AM »
I actually did think about that (my old tank was stripped)and now that you guys suggested I will get it done. Yes I do plan on foaming around the tank the boats flipped right now and I'm close to priming and paint my shops heated so I can keep chipping away at it.I'm using the interlux primekote what type profile should I leave for this primer to stick to best? 80 grit or 200 grit paper? Does it matter?
December 27, 2012, 05:25:59 AM
Thepipebender
« Reply #8 on: December 27, 2012, 05:25:59 AM »
Quote from: "gman 82 aquasport"
Nice looking tank!
I welded angle to the tank and bolted to my bulkhead but I do plan on foaming also.
