Yeah those bus bars have seen better days Seabob4 is also right that gregsmarinewire is where to buy your wire from, got all my wiring supplies there except bus bars and fuse box..They have good prices and great,fast shipping ..Also you can order different colors of wire when ordering 100 ft rolls(ie..20 ft of red, 20 ft of black, 60 ft of blue etc) they let you break up the amounts by colors, helps keep your cost down..Looks like a winter project..Rewiring isn't to difficult as long as you can get comfy while making connections, nothing like on your back half in -half out of your console
far as bilge pump access, do what Pete and Marc did on there Ospreys, install an access pie on the aft vertical face of the fishbox...
Quote from: "seabob4" far as bilge pump access, do what Pete and Marc did on there Ospreys, install an access pie on the aft vertical face of the fishbox...I agree, one of the best upgrades I ever did.
I have a 4" pie plate on the port side of my walk thru to get to the courtesy light. Easy as pie Well at least until you drop the wire and it disappears!
Quote from: "wingtime"I have a 4" pie plate on the port side of my walk thru to get to the courtesy light. Easy as pie Well at least until you drop the wire and it disappears!Coat hanger works good, Bruce...
