Author Topic: switching from twin to single outbord  (Read 1009 times)
May 13, 2006, 03:36:03 PM
Read 1009 times
hooked up
« on: May 13, 2006, 03:36:03 PM »
I have a 1986 "25" foot ccp profesional with a twin B-BRACKET. The bracket currently has 1993 175hp MERCURYS on it and i want to put a single 300hp SUZUKI on it. Is it posible to put a sigle outbord on a twin bracket? If anyone has done this or have any information i would greatly apprecite it.       THAKS!
Hooked-Up
1986 250 CCP
May 18, 2006, 03:43:56 PM
Twin to single
« Reply #1 on: May 18, 2006, 03:43:56 PM »
You could propably mount the single 300 in the center of your mount, but you will still have a big bracket on the back, exactly where it's not needed.  For the $$$ you are investing in a Zuki 300, you may want to go with a single motor bracket, or even consider a hydraulic jack plate.  This would clean up the back of the boat and leave more room for fighting fish, a swim platform, or whatever.
Bob's Machine is now selling a hydraulic jack plate that will work with a 300 hp - you can check it out at:  http://www.bobsmachine.com/
Let's go fishin' and good luck!
May 26, 2006, 07:44:23 AM
« Reply #2 on: May 26, 2006, 07:44:23 AM »
A fishing buddy of mine has a Grady-White 24 Offshore which I think came with a bracket.  It is drilled for twins and looks like it had them at one time.  It had an OceanRunner 200 when he bought it and he repowered with a single Yammie F-225.  It does okay but it could use a 300.  It never really gets on plane under 5000 rpm.  The type bracket he has does provide extra floatation but it is still a ton of weight.  I would consider replacing with a smaller bracket if it fits the budget.  Remember, you need the 30" bracket to allow the outboard to tilt fully up with a closed transom.
Something like this is what I would get if I ever close my transom.  Despite the company name, these are aluminum.
For you inboard guys, they carry a bunch of inboard stuff like risers, etc.
http://www.stainlessmarine.com/single.html
