Author Topic: RickK's 170 rebuild  (Read 78423 times)
December 24, 2013, 07:36:15 PM
Reply #585
Re: RickK's 170 rebuild
« Reply #585 on: December 24, 2013, 07:36:15 PM »
50 in the morn!!  Not even 2 hours N of you, we're supposed to see 37 or so... :shock:
December 24, 2013, 08:23:53 PM
Reply #586
« Reply #586 on: December 24, 2013, 08:23:53 PM »
Turning out nice Rick!  So, it looks like you recessed the whole latch so that its surface will be flush with the hatch...nice touch!
December 24, 2013, 08:41:59 PM
Reply #587
« Reply #587 on: December 24, 2013, 08:41:59 PM »
Quote from: "CLM65"
Thanks Craig.
I hate toe stubbers :evil:   I have a "camel back" on the deck in the 230 to hold the aft curtain and I step on the thing every time I'm in the boat.
I think you're supposed to recess them, no?
December 25, 2013, 12:13:35 AM
Reply #588
« Reply #588 on: December 25, 2013, 12:13:35 AM »
Quote from: "RickK"
Quote from: "CLM65"
Thanks Craig.
Good question.  It looks like the "flange" on those are pretty thick, so recessing is a great idea.  I've got some Southco latches for mine.  I haven't installed any yet, but the instructions on the Southco website indicate that they are surface mounted.  The flanges are slightly over 1/8" thick, so there will be a slight bump, but the edges are tapered, so I don't think they will be a stub hazard.  Either way, I think you will have a nice clean installation when you are done :thumright: .
I don't know if you have mentioned this, but are you installing two latches on your hatch?  Seems like there are two "resin pads" in the pics.  I guess this will eliminate the need for hinges.  Another nice idea :salut:
December 25, 2013, 06:49:12 AM
Reply #589
« Reply #589 on: December 25, 2013, 06:49:12 AM »
Quote from: "CLM65"
Quote from: "RickK"
The edge on these is pretty thick - and what it needed to recess them was pretty substantial.
You can always recess yours a little bit for a clean look.
Quote from: "CLM65"
Yup, 2 latches, no hinges.  Still want to play around with the spline idea for sealing.
December 28, 2013, 09:35:16 AM
Reply #590
« Reply #590 on: December 28, 2013, 09:35:16 AM »
Sole glued in with thickened epoxy on Christmas day
Filleted in this morning
Followed by tabbing it in
Sole is secure and part of the hull now  :cheers:
December 28, 2013, 10:24:25 AM
Reply #591
Callyb
  • MidWest
« Reply #591 on: December 28, 2013, 10:24:25 AM »
Congrats Rick! :cheers:
As Joe Biden would say, "It's kind of a big F****** deal". :salut:
Carl
___________________________
December 28, 2013, 10:52:46 AM
Reply #592
« Reply #592 on: December 28, 2013, 10:52:46 AM »
Congrats, Rick!  Major milestone there!
December 28, 2013, 12:23:29 PM
Reply #593
fishinonthebrain
« Reply #593 on: December 28, 2013, 12:23:29 PM »
Looks sweet you have really put the hammer down during the holiday season.  :thumleft:
1987 222CCP current rebuild.
December 28, 2013, 01:07:21 PM
Reply #594
dburr
« Reply #594 on: December 28, 2013, 01:07:21 PM »
On Christmas Day??? How in the world did you get away with that??? Huge accomplishment :cheers:  :cheers: !
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
December 28, 2013, 04:43:07 PM
Reply #595
fishinonthebrain
« Reply #595 on: December 28, 2013, 04:43:07 PM »
Quote from: "dburr"
I was thinking the same thing. The wife must really want this boat done.   :mrgreen:
December 28, 2013, 05:16:34 PM
Reply #596
gman 82 aquasport
« Reply #596 on: December 28, 2013, 05:16:34 PM »
Taking the year out with a bang :salut: She looks great with the floor in...headed for the final stretch :cheers:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
December 28, 2013, 06:13:23 PM
Reply #597
« Reply #597 on: December 28, 2013, 06:13:23 PM »
THANKS GUYS  :!:  :!:  It's been a long, tough but productive 30+ days.
To the casual viewer it may look like not much progress - the stringers were already there, the tank well was there, the sole was lam'd :scratch:
If I had to look back I guess the time was spent on the console and the hatches and some little stuff - wow - 30+ days on that  :shock:
December 28, 2013, 06:14:49 PM
Reply #598
« Reply #598 on: December 28, 2013, 06:14:49 PM »
Quote from: "Callyb"
:lol:
And it is.
December 28, 2013, 06:31:56 PM
Reply #599
« Reply #599 on: December 28, 2013, 06:31:56 PM »
I started working on the bolt holes that would secure the tank hatch and started by recessing the resin that I poured into the over-drilled holes for the bolts. I wish now that I would have filled these holes with epoxy - poly in that quantity is brittle and actually not worth much.  I think it will work as it's just a "vertical spacer".  We'll see.  I used a spade bit to recess and also give me a hole to use as a guide for the hole size.
