Author Topic: RickK's 170 rebuild  (Read 79904 times)
December 12, 2013, 01:03:39 PM
Reply #495
dirtwheelsfl
Re: RickK's 170 rebuild
« Reply #495 on: December 12, 2013, 01:03:39 PM »
Getting there!     Gaps look great..
December 12, 2013, 01:17:31 PM
Reply #496
« Reply #496 on: December 12, 2013, 01:17:31 PM »
Quote from: "Capt. Bob"
I'm guessing you're sealing the tank hatch with say, UV4000 (good choice by the way :idea: ) but what about the aft hatch where the pump is to be located?
Also, is that the loaf of bread Eddie stole during "neighbors nite out" ? :wink:
Good luck. :thumleft:
Sealing is still undecided and that is a sponge, not a loaf of bread  :roll:  (and it was neighbors nite out last night - sorry)
December 12, 2013, 01:59:57 PM
Reply #497
« Reply #497 on: December 12, 2013, 01:59:57 PM »
Quote from: "wingtime"
Wow that looks GREAT Rick!   It's exciting when pieces start to come together and you can see what the finished product is going to look like.  When ya planning on installing the deck permanently?
Thanks WT.
Not sure yet - things to do in the bilge still.  That will be one of those major decision times again - did I get everything done.....
I'm pretty happy with the results so far.  I'm waiting for a couple parts to arrive and then I can take some more major steps.
December 12, 2013, 02:02:51 PM
Reply #498
« Reply #498 on: December 12, 2013, 02:02:51 PM »
This build is better than the majority of "professional" jobs :thumright:
Thanks Scott, but I would hope that Pros are putting out at least this quality, hopefully better.
December 12, 2013, 02:40:06 PM
Reply #499
« Reply #499 on: December 12, 2013, 02:40:06 PM »
Quote from: "RickK"
Yes, you would hope and expect so...but for instance your tank install, hatch fit and finish, stringer detail, etc...most don't go there.
Like the framing crews around here say..."Can't see it from my house." :?
December 12, 2013, 05:28:52 PM
Reply #500
« Reply #500 on: December 12, 2013, 05:28:52 PM »
Quote from: "RickK"
Well I was going to inquire whether it was whole wheat or rye but in that case I'll ask..........
Contraceptive :scratch:
December 15, 2013, 05:59:34 PM
Reply #501
« Reply #501 on: December 15, 2013, 05:59:34 PM »
Made a mold to create "trim rings" (maybe not the right term) for the cabling to go through into the rigging tubes.
Cut the 2nd layer of Plascore for under the batteries - you can see the red outline of where it will lam'd in faintly through the visqueen just to the left of one of the finished trim rings.
December 15, 2013, 06:02:37 PM
Reply #502
« Reply #502 on: December 15, 2013, 06:02:37 PM »
Borrowed one of Chris's techniques for the drain plug - was going to go with a normal expansion plug but decided to go with a garboard plug.
EDIT: I guess I should explain why this is a better technique it you are using a garboard drain plug.  The PVC plug is about 3/4" thick,which is the hole depth (I actually only got into about 1/4" of wood), and the thickened resin "filler" you see is where the screws for the garboard plug will land.  So the wood transom is protected from screw holes. I may do the same technique for the motor mounts.
December 15, 2013, 06:05:06 PM
Reply #503
« Reply #503 on: December 15, 2013, 06:05:06 PM »
Did a final grind in the bilge area and vacuumed/wiped it clean
Rolled some 2-part epoxy paint on.
December 15, 2013, 06:22:34 PM
Reply #504
Callyb
  • MidWest
« Reply #504 on: December 15, 2013, 06:22:34 PM »
Is that insert for the garboard plug two PVC pipes? Very interesting concept. How well does the resin stick to it if so?
Oh, that bilge looks amazing! :salut:
Carl
___________________________
December 15, 2013, 06:37:03 PM
Reply #505
« Reply #505 on: December 15, 2013, 06:37:03 PM »
Quote from: "Callyb"
yup - 1" for the inner and 2" for the outer.  Thickened epoxy for the filler - sticks fine to it. Epoxied it into the transom.
Thanks, I mixed twice as much as I needed, as usual :roll: Potent stuff.
December 16, 2013, 06:04:23 AM
Reply #506
« Reply #506 on: December 16, 2013, 06:04:23 AM »
It does look good, Rick!  What paint did you use for the bilge?
December 16, 2013, 06:32:18 AM
Reply #507
« Reply #507 on: December 16, 2013, 06:32:18 AM »
E-bond epoxy http://fiberglasssupplydepot.com/E-Bond ... 06c-2.html
The instructions on the can leave a lot to be desired. You mix it 1:1 (never really seems to mix up though) and I was told you get about 30 mins working time - I checked back a little later and it was tacking up. I should have mixed up a pint total but mixed a pint of each - really thin stuff.  Use good ventilation or a respirator.  I used denatured alcohol to clean the roller handle - no clean up instructions on the can.
December 16, 2013, 07:10:57 AM
Reply #508
Callyb
  • MidWest
« Reply #508 on: December 16, 2013, 07:10:57 AM »
Why post once when you can post twice? :oops:
Carl
Reply #509
Callyb
  • MidWest
« Reply #509 on: December 16, 2013, 07:10:57 AM »
Rick, white vinigar cleans up uncured epoxy better than anything else I have found. :wink:
Carl
