Author Topic: RickK's 170 rebuild  (Read 79905 times)
December 11, 2013, 06:15:16 AM
Reply #480
Re: RickK's 170 rebuild
« Reply #480 on: December 11, 2013, 06:15:16 AM »
Quote from: "Aswaff400"
Quote from: "CLM65"
Congrats on the foam completion, Rick :cheers: !  Looks great!  So let me get this straight...You mixed 2 quarts at a time (one quart of each part), and that was enough to fill at least a few feet of stringer?  I'm hoping to foam mine this weekend, so I really appreciate the info!
I want to say I mixed  a gallon when I poured, and I think 8 gallons total, 4 of part a, 4 of part b, 4 lb foam.
Man that's a lot of money in foam  :shock:  :shock:
December 11, 2013, 06:20:36 AM
Reply #481
« Reply #481 on: December 11, 2013, 06:20:36 AM »
Quote from: "RickK"
Quote from: "CLM65"
yup, just checked my book, 8 gallons of 4 lb, 4 of A, 4 of B. was the exact amount needed for my stringers
December 11, 2013, 06:32:21 AM
Reply #482
« Reply #482 on: December 11, 2013, 06:32:21 AM »
Oh that reminds me - the foam I used is 2lb.
December 11, 2013, 11:50:00 AM
Reply #483
« Reply #483 on: December 11, 2013, 11:50:00 AM »
Yea, the 2 lb versus 4 lb density will definitely make a difference.  I have the 80 lb/20 cubic foot kit of 4 lb foam.  That is probably about what Aaron used, since it came in two 5 gallon containers (probably about 4 gallons of liquid in each).  The way I did my stringers, I'm sure I will need more foam than Aaron did.  Well that is just great.  More money....
December 11, 2013, 12:26:44 PM
Reply #484
« Reply #484 on: December 11, 2013, 12:26:44 PM »
OK I have a foam question.  The 2lbs or 4lbs foam... how is that figured?  The weight per cubic foot of the cured foam?
December 11, 2013, 01:38:56 PM
Reply #485
« Reply #485 on: December 11, 2013, 01:38:56 PM »
Quote from: "wingtime"
Yes, it is the approximate weight of one cubic foot of the cured/expanded foam.  As I understand it, the amount of expansion is affected by temperature, with 80°F or greater being about optimum.  So if it was colder, it may not expand as much, and would be a little more dense (one cubic foot would weigh more).
December 11, 2013, 02:17:14 PM
Reply #486
« Reply #486 on: December 11, 2013, 02:17:14 PM »
Here's a little something for the non re-builders who haven't read it yet. :idea:
http://www.boatdesign.net/forums/materi ... 963-2.html
Three pages but on page 2, a couple three pics of foam.
Look familiar? :scratch:
One more from the CW group
http://continuouswave.com/ubb/Forum1/HTML/003674.html
Opinionated for sure on the foam but many have found wet foam in their Aquas so I'd say it can absorb water at some point in its life.
Interesting indeed.
December 12, 2013, 06:09:21 AM
Reply #487
Callyb
  • MidWest
« Reply #487 on: December 12, 2013, 06:09:21 AM »
Congrats Rick! That is a big milestone, at least a mental one for sure! :salut:
Carl
___________________________
December 12, 2013, 08:43:37 AM
Reply #488
« Reply #488 on: December 12, 2013, 08:43:37 AM »
CB, enjoyed reading that lengthy and quite technical dissertation on CW.  Surprised Jim H didn't end the thread with the definitive reason (his own) as to why Whaler foam absorbs water.  He is, after all, THE expert on everything Whaler...just ask him. :roll:  :roll:
December 12, 2013, 11:28:06 AM
Reply #489
« Reply #489 on: December 12, 2013, 11:28:06 AM »
Just checking
December 12, 2013, 11:30:36 AM
Reply #490
« Reply #490 on: December 12, 2013, 11:30:36 AM »
December 12, 2013, 11:30:55 AM
Reply #491
« Reply #491 on: December 12, 2013, 11:30:55 AM »
December 12, 2013, 11:36:49 AM
Reply #492
« Reply #492 on: December 12, 2013, 11:36:49 AM »
Wow that looks GREAT Rick!   It's exciting when pieces start to come together and you can see what the finished product is going to look like.  When ya planning on installing the deck permanently?
December 12, 2013, 12:50:22 PM
Reply #493
« Reply #493 on: December 12, 2013, 12:50:22 PM »
I'm guessing you're sealing the tank hatch with say, UV4000 (good choice by the way :idea: ) but what about the aft hatch where the pump is to be located?
Also, is that the loaf of bread Eddie stole during "neighbors nite out" ? :wink:
Good luck. :thumleft:
December 12, 2013, 12:56:39 PM
Reply #494
« Reply #494 on: December 12, 2013, 12:56:39 PM »
This build is better than the majority of "professional" jobs :thumright:
