Author Topic: RickK's 170 rebuild  (Read 80121 times)
September 07, 2013, 07:17:39 PM
Reply #345
Re: RickK's 170 rebuild
« Reply #345 on: September 07, 2013, 07:17:39 PM »
I have a couple of layers to go
Started filling the old holes in the console - will need a few more layers
September 07, 2013, 07:22:23 PM
Reply #346
« Reply #346 on: September 07, 2013, 07:22:23 PM »
Then, while the console was doing it's hardening thing, I started cutting the sole in - came out not too shabby.  :cheers: The casting deck comes in at 10.5 ft and what you see is 12ft of sole.
September 08, 2013, 06:27:52 PM
Reply #347
« Reply #347 on: September 08, 2013, 06:27:52 PM »
Got the sole glassed on both sides - Poly on one side (top) and epoxy on the other.
September 08, 2013, 07:33:23 PM
Reply #348
« Reply #348 on: September 08, 2013, 07:33:23 PM »
Looking really good, Rick!  What did you use for glass on each side?
September 09, 2013, 04:58:22 AM
Reply #349
« Reply #349 on: September 09, 2013, 04:58:22 AM »
On the top I have a layer of 3/4oz and on the bottom a layer of 1708.
September 09, 2013, 11:37:01 AM
Reply #350
« Reply #350 on: September 09, 2013, 11:37:01 AM »
Wow, I was under the impression that 1 or 2 layers of 1708 per side was needed for the honeycomb cores, with perhaps a layer of 3/4 mat on top to give a smoother finish.  How solid does it feel?
September 09, 2013, 01:29:20 PM
Reply #351
dirtwheelsfl
« Reply #351 on: September 09, 2013, 01:29:20 PM »
Pretty work!
Quote from: "CLM65"
I would guess hes waiting til its in the boat to do the rest so its lighter to lift and move?
September 09, 2013, 08:57:17 PM
Reply #352
« Reply #352 on: September 09, 2013, 08:57:17 PM »
I'll top it with two layers of 1708 - just trying to get it all connected and stable right now.  It is getting heavy already.
September 09, 2013, 10:00:30 PM
Reply #353
« Reply #353 on: September 09, 2013, 10:00:30 PM »
Quote from: "RickK"
 :thumleft: makes sense!
September 22, 2013, 04:36:12 PM
Reply #354
« Reply #354 on: September 22, 2013, 04:36:12 PM »
Lam'd another layer of 1708 on the bottom of the sole yesterday and this morning my wife and I lifted it onto the saw horses - maybe weighs 60-70 lbs now.
I marked the sole where the stringers are, the tank coffin is, where the old console sat (aft side) and where the casting deck starts just to visualize everything.
Then I rolled the console up and placed it on the sole where the old sat and where the new will sit.
September 22, 2013, 04:36:50 PM
Reply #355
« Reply #355 on: September 22, 2013, 04:36:50 PM »
September 22, 2013, 04:37:14 PM
Reply #356
« Reply #356 on: September 22, 2013, 04:37:14 PM »
Scruffed up the console and lam'd another 2 layers of 1.5oz on the sides and added a few layers to fill in the holes on the front
Another weekend gone.
September 22, 2013, 04:39:51 PM
Reply #357
« Reply #357 on: September 22, 2013, 04:39:51 PM »
Like the toe kick :salut:
September 22, 2013, 04:48:18 PM
Reply #358
« Reply #358 on: September 22, 2013, 04:48:18 PM »
It'll be cool I think - the console is kinda wide so that'll make it a little easier to walk to the front.
I also cut a pipe in and glued it in for routing the bilge pump discharge hose to the Starboard side and glued some pipe in for the gas tank fill and vent hoses to pass through. So the little things are getting done too.
September 22, 2013, 06:29:31 PM
Reply #359
« Reply #359 on: September 22, 2013, 06:29:31 PM »
It's really coming together, Rick.  I like what you are doing with the console.  I don't have one for my 22-2, and I haven't found one yet that quite meets my needs exactly.  So you are inspiring me to think about making one myself.  Not convinced I can do it yet...but I'm thinking about it :roll:
