165/170/175 Rebuilds
RickK's 170 rebuild
88
89
90
91
93
Topic: RickK's 170 rebuild (Read 75329 times)
September 05, 2016, 01:29:14 PM
Reply #1320
Re: RickK's 170 rebuild
Reply #1320 on:
September 05, 2016, 01:29:14 PM »
I lost a couple days of working on the boat this long weekend, due to work
Happy Labor Day!!
Anyway, I was not real confident on the plan I had for securing the seat to the deck - I was going to use stainless inserts and had over-drilled and filled the holes with thickened resin. It's been eating at me in the back of my mind for months. So I got to work on the boat Sunday and drilled a 1" hole down almost to the stringers, through the plugs I had poured earlier. I cleaned out all the plastic and made sure I had a nice flat bottom for my new plan.
I had some 1/4 - 20 threaded rod laying around and had 7 of the T-nuts left. So my plan was to mix up some thickened epoxy and press the t-nuts to the bottom of the hole and fill the holes with the epoxy. I taped the bottom of the seat platform so any spilled epoxy wouldn't stick to them and set the seat down on top of the threaded bolts to keep them aligned. I sprayed the bolts with some lubricant so the epoxy wouldn't stick and I could remove them - hard to see the bolts but they are in the holes on the inside of the seat platform. Got up and rotated the bolts throughout the day until the epoxy hardened. Worked out well. I have confidence that these will allow securing the seat without letting water down into the stringers.
December 21, 2016, 03:44:30 PM
Reply #1321
Reply #1321 on:
December 21, 2016, 03:44:30 PM »
Started back on the boat over the past few days - working the grueling non-skid
The non-skid isn't bad, it's the double masking and all the transitions.
Started at the front and finished the casting deck and added some water run lines on the floor
Started the masking on the forward deck and then rolled the gelcoat and applied the glass bead
Let it kick, then swept off the excess and pulled the first layer of tape
Then topcoated it and let it kick
Did the front of the tank lid
Then started working the aft of the boat - a day of masking alone
I really should have broke it into two sides but I didn't - almost too much room to handle before the gelcoat kicks.
But got it done
I would not like to fall down on this stuff - talk about coming up with road rash. Next is to gelcoat the remaining section of the lid - it will be grey without non-skid.
December 21, 2016, 06:11:07 PM
Reply #1322
Reply #1322 on:
December 21, 2016, 06:11:07 PM »
Looking good. Non skid! Wow! You're so close that you must be tasting the salt spray. What are you useing for your non skid?
December 21, 2016, 07:15:32 PM
Reply #1323
Reply #1323 on:
December 21, 2016, 07:15:32 PM »
gelcoat and glass bead - see this post and the one after Lar's comment to see the process up close
http://classicaquasport.com/smf/index.php?topic=10101.msg135182#msg135182
December 22, 2016, 05:06:29 PM
Reply #1324
Reply #1324 on:
December 22, 2016, 05:06:29 PM »
Rolled gray gelcoat on the middle of the tank lid - this portion will be inside the console.
Set it back in the boat
I forgot to take pics of the other non-skid I did over the past few days
Added this on both gunwale tops for the step into the boat
And this on the top of the transom
Then I laminated up the "tank keeper" with some Plascore and 1708 using epoxy. It is the piece that fits in the middle slot on the tank to keep it from moving
The tank well is pretty tight so it's not going anywhere but up if we take a big wave.
You get a glimpse of it here
December 24, 2016, 01:40:37 PM
Reply #1325
Reply #1325 on:
December 24, 2016, 01:40:37 PM »
Made up some Plascore with 1708 and epoxy on both sides - pretty stout with just a single layer on both sides. Then I cut some uprights to attach to the sides of the tank coffin. I cut 3/4" H x1/4"W slots in them so I can raise the keeper out of the slot a little and then mixed up some thickened epoxy and glued them to the main keeper.
I pulled the glued keeper back out after it hardened a little and ground away any excess. Put it back in and drilled some small marks at the top of the slot to locate the stainless threaded inserts. Pulled the keeper back out, drilled the correct size holes and threaded in the keepers. Then I re-installed the keeper and put some high strength loctite on the truss bolts I screwed into the inserts - I left them a little loose so the keeper can move a little but raised the keeper out of the slot about 3/8" before I snugged them down.
After I attached the keeper I glued a brace down the middle of the keeper for added rigidity - she ain't going anywhere.
Keeper raised up
Next is chasing out the threads of all the threaded inserts around the perimeter of the tank lid, pulling the cables, wires etc through the access holes and setting and sealing the lid down.
December 26, 2016, 04:20:59 PM
Reply #1326
Reply #1326 on:
December 26, 2016, 04:20:59 PM »
Time to button it up. Sorted all the stuff out to the proper sides and made sure I have access to the pull lines I ran in each tube
I got everything through the access holes and piled it up in the middle, inside where the console will be.
Next I added rubber washers under the truss bolts I anchor the tank lid with. I also pumped caulking in the holes to seal them up. Some oozed out but no big deal.
Then it was time to caulk the lid to make it water tight. I ran two strips of tape around the lid so I could do a nice job of filling the gap with the 4000UV
Then I filled it
And used a fillet tool to smooth it out - kept dipping it in mineral spirits.
Then removed the tape - had to fuss with the corners a bit with my finger dipped in mineral spirits. Came out ok and it's sealed
Onward
December 27, 2016, 02:03:44 PM
Reply #1327
Reply #1327 on:
December 27, 2016, 02:03:44 PM »
Hung the power pole this morning and plumbed it.
Mounted the rear hatch hardware
Finished the loom into the starboard cabinet
Onward
December 27, 2016, 11:26:26 PM
Reply #1328
MarcG
Reply #1328 on:
December 27, 2016, 11:26:26 PM »
Looking good! Was the Power Pole a Christmas present?
I wasn't considering additional accessories like that on my rebuild - I better go a little larger when I install the chase tubes under the floor just in case.
December 28, 2016, 05:08:59 AM
Reply #1329
Reply #1329 on:
December 28, 2016, 05:08:59 AM »
Thanks Marc. I've had this Power Pole for about 10 years and it was installed on the boat before the rebuild, but through the transom. This time I added a mounting bracket so I don't have extra holes in the transom. If you plan to put the pump in the console, the only thing coming back to the pole is two very small hydraulic lines.
December 28, 2016, 02:17:14 PM
Reply #1330
larsli68
Reply #1330 on:
December 28, 2016, 02:17:14 PM »
Great work as always Rick, and great progress!
Can't wait to see some on the water pictures!
Happy New Year!
//Lars
December 29, 2016, 05:45:36 PM
Reply #1331
Reply #1331 on:
December 29, 2016, 05:45:36 PM »
Thanks Lars - making good progress now.
Dropped the console in and bolted it down. Fits like a tight pair of shoes - very tight. Also caulked around the base.
I guess I have to replace the screws that are already rusting on the speakers.
I spent a few days, months ago, pre-wiring inside the console, so all that is done. I spent the rest of the day routing the cables from below (the majority of the time) and connecting wires. Only have a few more connections to make, connect the shift/throttle cables to connect to the binnacle and then mount the binnacle, wire the trim/tilt and neutral safety switch. Mount the steering wheel. I think I'm going to extend the warning buzzer wire on the ignition switch and mount it in the opening of the vent on the side of the console so I can hear it. I also have to connect the power pole hoses - there was just enough length, could have used an extra foot. Then I'll add hydraulic fluid to the pole and the steering. Probably a half day's worth of work in the console. On the boat itself I have the hinges to install on both front hatches (I'd love to find thinner hinges), seat, rub rail, the registration numbers/tags and a new jack on the trailer.
December 30, 2016, 08:36:10 AM
Reply #1332
larsli68
Reply #1332 on:
December 30, 2016, 08:36:10 AM »
It looks beautiful! Very nice!
I plan to re-do my electrical installation. I need to do a better job at routing the cables, and make it look nicer. I was in a rush getting it done two years ago.
Happy New Year!
//Lars
December 31, 2016, 07:31:37 PM
Reply #1333
Reply #1333 on:
December 31, 2016, 07:31:37 PM »
Wow, Rick, looks fantastic! Can't wait to see some action shots. What is the next project going to be?
January 01, 2017, 06:15:11 AM
Reply #1334
Reply #1334 on:
January 01, 2017, 06:15:11 AM »
Looks great! I guess the rub rail is next.
88
89
90
91
93
RickK's 170 rebuild
