165/170/175 Rebuilds
RickK's 170 rebuild
85
86
87
88
93
Topic: RickK's 170 rebuild (Read 75341 times)
June 01, 2016, 05:12:23 AM
Reply #1275
Re: RickK's 170 rebuild
Reply #1275 on:
June 01, 2016, 05:12:23 AM »
Thanks Lars and Craig. As for the lock washers - I thought the same with the nylocs being enough but wondered why they would include the lock washers with the bolts and nuts in the 2" spacer kit.
June 01, 2016, 09:44:57 AM
Reply #1276
love2fish
Reply #1276 on:
June 01, 2016, 09:44:57 AM »
might be thinking you could use the lock washer on the bolt head side- to hold the bolt incase you cant get a wrench to it...? not the best method but could work in a pinch I suppose. or... like most things you have to assemble these days- its always a crapshoot whether you get a matching number of nuts-bolts-washers.
boat looks great! I'm not familiar with the 17 bows really, is that removable section a custom thing you did? how does it stay locked in while you are underway? latches underneath or something?
Chris
\'74 22-2
Member #921
June 01, 2016, 12:25:34 PM
Reply #1277
Reply #1277 on:
June 01, 2016, 12:25:34 PM »
Thanks.
If you're talking about the big wood piece, I have not installed the swivel keeper blocks on the sides yet.
June 12, 2016, 03:39:48 PM
Reply #1278
Reply #1278 on:
June 12, 2016, 03:39:48 PM »
I worked on the proper placement of the engine/all the spacers to get the engine's anti-cavitation plate near the bottom of the boat when the jack plate is all the way down. I ended up raising the engine to the top hole on the jack plate and the bottom hole on the engine. That got the plate to be 1" above the bottom of the boat, which I think will be fine with 8" of set back. Sound right?
After that my buddy Ed and I decided it was time to dunk this baby and see if she floats. Aired the tires up, unhooked the front tarp attachment and moved the gantry to the side. I pulled the boat out of it's hiding place (in plain sight) and parked it on the road so I could clean up the years worth of leaves, dirt, shell and other stuff that accumulated under the boat. Cleaned and washed that all down and then off to the lake down the street to try her out. Boat is so light I don't even feel it behind the truck.
I have never launched at the lake so I didn't know what to expect. You're launching from shore, so I asked Ed to be ready to yell if something weird happened.
It went ok, almost had to back the truck into the water to get the boat to launch. I found out later, when I retrieved the boat, that the trailer was floating and I really didn't need to back in that far. I guess I'll need to put some weight (maybe a few hundred pounds) on the trailer.
The lake is a "no motor" lake so I guess I still qualify
I am happy to see the scuppers sitting high and dry - even with a couple more hundred pounds of the rest of the engine being added - should be self baling again
June 12, 2016, 09:50:44 PM
Reply #1279
Reply #1279 on:
June 12, 2016, 09:50:44 PM »
Awesome!
June 12, 2016, 10:02:46 PM
Reply #1280
Reply #1280 on:
June 12, 2016, 10:02:46 PM »
Looking good! Shouldn't be long now. Engine height should be good, but you'll want to run her to confirm.
June 13, 2016, 01:01:39 AM
Reply #1281
larsli68
Reply #1281 on:
June 13, 2016, 01:01:39 AM »
Really cool Rick! Must have felt great after all the hard work you have put in!
//Lars
June 13, 2016, 08:59:03 AM
Reply #1282
HawgLeg
Reply #1282 on:
June 13, 2016, 08:59:03 AM »
Saweeeet!! I'm thinking I'm going to float mine before I cut my scuppers
1970 Aquasport 22-2 Flatback with Yamaha F200
June 13, 2016, 09:11:57 AM
Reply #1283
Reply #1283 on:
June 13, 2016, 09:11:57 AM »
Thanks guys - it does feel good not only to float her but to get rid of all the crap that accumulated under the boat.
I need to get working on the engine now and also finish up the little bit of gelcoating I have left to do on the tank lid so I can get the console in. All the wiring has been pulled into the tank area.
July 09, 2016, 06:58:30 PM
Reply #1284
Reply #1284 on:
July 09, 2016, 06:58:30 PM »
Got the power head installed today - it took a little time to order and install the parts that I forgot to remove when I traded in the engine core - DOH!!.
I now need to discuss with you guys where you attached the circuit breaker and relays for the jackplate under the cowl. I will take and post some pics of the under cowl room and there isn't any on the port side for sure. Where would you install the items - the relays aren't small. I can install them in the cabinets in the rear corners of the boat but would rather put them up under the cowl.
July 11, 2016, 08:27:42 PM
Reply #1285
Reply #1285 on:
July 11, 2016, 08:27:42 PM »
I seem to have misplaced the clips that hold the engine side harness plugs to the helm side of the harness. Does anyone know where to purchase them? or even what the name of them are - I've googled my butt off with no success.
Thanks in advance.
July 16, 2016, 02:54:43 AM
Reply #1286
larsli68
Reply #1286 on:
July 16, 2016, 02:54:43 AM »
Hello Rick,
You probably have already seen this, but I found this place when helping my brother with parts for his 1999 Johnson.
You can click on view parts catalog without signing up for anything.
http://epc.brp.com/SiteMods/BRP_Public/BRP_Public_Login.aspx?ReturnUrl=%2fIndex.aspx%3flang%3dE%26s1%3d91f0aa45-071b-4748-aae1-91a549252d9c&lang=E&s1=91f0aa45-071b-4748-aae1-91a549252d9c
It will give you exploded views of the different areas of the engine.
//Lars
July 16, 2016, 05:56:55 AM
Reply #1287
Reply #1287 on:
July 16, 2016, 05:56:55 AM »
Thanks Lars
Yup, I found this site and many others that show exploded views (maybe behind the scene they all come back to this one) and I finally found the clips by looking at a different model than mine - not sure why the clips aren't on every one
July 18, 2016, 06:07:15 PM
Reply #1288
Reply #1288 on:
July 18, 2016, 06:07:15 PM »
Found some rotten wires in the internal wiring harness and had to order a new harness.
Changed the impeller again (changed it when I started this rebuild), test fit the lower unit and drained/filled the lower unit lube. We found that we were missing a grommet so I ordered that and we'll finish it up next weekend.
July 18, 2016, 09:23:52 PM
Reply #1289
Reply #1289 on:
July 18, 2016, 09:23:52 PM »
Getting mighty close Rick! Can't wait to see it running!
85
86
87
88
93
RickK's 170 rebuild
