So first, some background: traded for this motor (for an item that cost me $0). Motor is a 1998, 3cyl, 2stroke 40hp Yamaha with oil injection. Got her from a mechanic who took the motor from a customer as partial payment. It has a new starter, impeller, starter relay, 3 coils, 3 spark plugs, and battery cables. Mechanic said after he replaced all that, it would idle rough, but would run...compression was tested at 110, 110, 50 (or so he says, I've not tested it, nor performed a leak-down test).Tonight, I put her in a tub of water on the stand, and immediately realized that I have no Yamaha keys Used a small key from work the get the switch to "on" but not "start" and just jumped the starter terminals from there.As advertised, she lit right off, but ran rough. We pulled the plug wire on the cylinder advertised as being low and nothing much changed (if anything it got slightly smoother). Replacing it and pulling either of the other two killed the motor unless you throttled up. Next, we switched the plug on the bad cylinder with the one above it...2 of us witnessed the results or I'd think I was confused...pulling the cap on the cylinder that was advertised as low acted like it wanted to kill the motor...BUT so did pulling the cap on the one above...this time, pulling the cap on the plug we didn't touch was the only thing that didn't markedly affect the motor's attitude.Other notes: Red oil(?) light was on on the front of the motor in spite of adding 2stroke oil. Revving in neutral acted like it was hitting a limiter far earlier than I'd think it should have and it only peed for a brief moment in the middle of all of this messing.Any revelations based on all this info? I'm hoping to limp it around and duck hunt while there's still some season left, and then tear into it...so maybe run some Seafoam through it and carry a paddle for the next month? Looking into the spark plug hole on the "low" cylinder showed an oil (carbon?) covered piston. Definitely sparking (shocked the dog poo out of you if you grabbed with bare, wet hands.)
Head is stuck on the block. :evil: Mallet? Heat?
Overbore pistons and a day at the machine shop won't cure what ails me? We've had dirtbike motors literally blow chunks of piston everywhere and we just get it punched out and buy the corresponding piston/rings for the new overbore.
