Author Topic: What do you guys think?  (Read 3968 times)
January 27, 2013, 08:05:39 PM
Reply #75
Re: What do you guys think?
« Reply #75 on: January 27, 2013, 08:05:39 PM »
Quote from: "RickK"
I'm pretty sure my 230 with full fuel and 40gals of water plus all the camping supplies tips the scale at the max my Tundra can handle (6900 lbs).  The Tundra handles it ok but you know the boat is back there (by the gas mileage too).
That sounds about right Rick, I had a blowout on my left front tire coming back from lake O doing 70, ran over something that put a nickle size hole in the tire so the air went out real quick, I was glad to be towing with my f250 on that one.
January 27, 2013, 08:25:39 PM
Reply #76
« Reply #76 on: January 27, 2013, 08:25:39 PM »
Quote from: "Circle Hooked"
Quote from: "RickK"
DAMN!!! :shock:  :shock:  :shock:
January 27, 2013, 08:39:24 PM
Reply #77
« Reply #77 on: January 27, 2013, 08:39:24 PM »
I second that, I had just got back into the right lane after passing a slow truck and was coming off River road overpass and bang, no warning,  must have hit a piece of rebar just right or something like that.
January 27, 2013, 08:48:39 PM
Reply #78
« Reply #78 on: January 27, 2013, 08:48:39 PM »
How did the boat run with your new throttle cable?
January 27, 2013, 09:44:56 PM
Reply #79
« Reply #79 on: January 27, 2013, 09:44:56 PM »
Well I hate to admit it but I never ran the boat with the new cable before the trip, just on the hose so once I got it in the water the rpms where way to low and it would stall going into and coming out of gear so I had to do some adjustments on the water but after that all was good.
January 27, 2013, 10:01:28 PM
Reply #80
« Reply #80 on: January 27, 2013, 10:01:28 PM »
 OT
How did ya'll do on the fish?  We've been interested to hear :cheers:
Let us know on the NFL thread on chum, so as not to thread-steal here.
Looking forward to good news :thumright:
Thanks all.
January 28, 2013, 12:09:53 AM
Reply #81
jahoward1
« Reply #81 on: January 28, 2013, 12:09:53 AM »
Quote from: "wingtime"
I'd say a 225 will weigh in over 5400 lbs on the trailer fully loaded. I'm sure some 225 and 230 guys will chime in on weights and towing. I personally would like to have a tad more capacity than the load I'm towing.
The dealer advised in an email: The trailer is manufactured by Sealion Trailers it is their model SE-23T-5400BB. It has a 5,400 lb carrying capacity and a gross weight (the amount you will be towing) of 6,550 lbs. Two torsion axles (better than leaf springs) and 4 wheel disc brakes. The type of braking system is hydraulic surge, this is typical on boat trailers. Horse and motor home trailers use electric brakes. It will come with a two year warranty.
If I bought this boat, http://www.yachtworld.com/boats/2001/Aq ... ted-States
I'd have to buy a trailer and I don't understand the difference between a trailer having a $5400lb towing capacity and the gross weight being the weight you will be towing.  With this information, would this be the right sized trailer to tow a 225 loaded with the motor, gas, water and gear?
1997 Aquasport 200 Osprey
"Sally May"
January 28, 2013, 12:27:22 AM
Reply #82
« Reply #82 on: January 28, 2013, 12:27:22 AM »
Pretty easy do do, huh?
January 28, 2013, 12:50:13 AM
Reply #83
« Reply #83 on: January 28, 2013, 12:50:13 AM »
Quote from: "jahoward1"
That trailer may work but I like to always go bigger, my trailer is made for a 24 ft boat and has 3500lb axles so in theory it should hold 7000lb or more.
Bob it was pretty easy  :thumright:
