Author Topic: New Owner Questions  (Read 1743 times)
November 28, 2012, 08:58:26 AM
CCPorter
Re: New Owner Questions
« Reply #15 on: November 28, 2012, 08:58:26 AM »
Quote
On my 20' XF (walk around version of your hull) The deepest draft of the hull was the bottom of the deep vee about 1/3 back from the bow. With the motor trimmed up you will hit bottom with the bow before the motor or the stern hits. She will easily float in knee deep water.
that's perfect......thanks.
November 28, 2012, 07:40:15 PM
200CCPMerc200
« Reply #16 on: November 28, 2012, 07:40:15 PM »
that walk around is alot heavier midship,the 200ccp is 1800lbs. dry,Mine is lower at the stern with a V6 Merc on an 8" jackplate, and a 15hp honda 4 stroke kicker,the j/plate raises my motor about 3" higher than bolted to transom,and she bolts out of the hole and planes fast.
Aquasport 200 CC Pro, 200 Merc,15hp Honda,Hydrostream Varmint Bassboat,2.4 Merc Bridgeport, Shadow VT200, tunnel hull,merc., 225 Promax.
