wow....thanks....that is actually perfect. i will call them asap. i'll obviously double check on the size....thanks again.
jdupree - THANKS!!!!!! I just got off of the phone with them and bought the box.I never would have found that.....it'll be perfect.....can't wait to get it on.
Quote from: "CCPorter"jdupree - THANKS!!!!!! I just got off of the phone with them and bought the box.I never would have found that.....it'll be perfect.....can't wait to get it on.Another thing, I am sure you will but be sure to mount that coffin to the deck. You will most likely see holes in it from the original install. They were mounted with aluminum angle iron. The drain in the coffin box should line up with your drain on the deck. You might even want to check the CCP the coffin came out of. The mounts might still be mounted to the deck. If you have any questions just let us know.
