Author Topic: 1966 22-2 Diver Rebuild  (Read 20333 times)
April 21, 2014, 02:04:55 PM
Reply #270
Callyb
  • MidWest
Re: 1966 22-2 Diver Rebuild
« Reply #270 on: April 21, 2014, 02:04:55 PM »
Yes, and I will lay a fillet of thickened epoxy down on the bottom and in the corners of the coffin area too.
I am on the fence about doing an ambient layup or vacuum bagging it.
Carl
___________________________
April 21, 2014, 02:15:14 PM
Reply #271
« Reply #271 on: April 21, 2014, 02:15:14 PM »
Looks good Carl - nice idea :salut:
Be sure to leave way more than you think you'll need for expansion of that tank - don't want to get into the saga I did  :oops:   All that cloth will fill in your gaps quickly.
April 21, 2014, 02:43:09 PM
Reply #272
Callyb
  • MidWest
« Reply #272 on: April 21, 2014, 02:43:09 PM »
Thank you Rick.
I have 3/4" all the way around for expansion, which by my calculations should be good to go for my size tank.
Carl
April 21, 2014, 03:54:35 PM
Reply #273
« Reply #273 on: April 21, 2014, 03:54:35 PM »
Quote from: "wingtime"
Hey that's a pretty cool idea to pour and shape the foam first.  Cool idea. Just proves there is more than one way to skin a cat!  :shock:
with all the rebuilds going on right now we're seeing a lot of dead kitties :lol:
April 21, 2014, 05:05:36 PM
Reply #274
« Reply #274 on: April 21, 2014, 05:05:36 PM »
Quote from: "Callyb"
Craig, yes I only have one done so far. The obvious answer is to just put the chase tubes in the port stringer, but I dont know if the shift and throttle cable will make the bends without binding (maybe Seabob could help with that) since they need to come out of the transom on the port side.
Good question.  I will have one tube (2" if it will fit) going straight from the front of the bilge area to under the console just in case....
April 21, 2014, 08:21:18 PM
Reply #275
« Reply #275 on: April 21, 2014, 08:21:18 PM »
Carl, if you use Teleflex XTreme or Morse 33C Supreme cables, you'll have no problems.  Both can do 4" bend radii with no problems.  Not that you want to get your bends that tight, but you know what I mean...
April 21, 2014, 08:33:20 PM
Reply #276
Callyb
  • MidWest
« Reply #276 on: April 21, 2014, 08:33:20 PM »
I got ya, thank you Sir. I appreciate it. I may just say the hell with I and put a chase in the port stringer then.
Carl
April 22, 2014, 04:46:52 PM
Reply #277
fishinonthebrain
« Reply #277 on: April 22, 2014, 04:46:52 PM »
Wow the stringers came out nice even through the miss haps. The pipe in the stringer for your wires would have been really cool too but....
It seems like every plan has a way of changing. Looks really good though. :salut:
1987 222CCP current rebuild.
April 23, 2014, 06:02:54 AM
Reply #278
Callyb
  • MidWest
« Reply #278 on: April 23, 2014, 06:02:54 AM »
Thanks Fish. I'm in the same frame of mind about the rigging tubes... I'm over it. :lol:
Carl
April 24, 2014, 06:10:37 AM
Reply #279
Callyb
  • MidWest
« Reply #279 on: April 24, 2014, 06:10:37 AM »
Second verse, same as the first...
I started moving the forms to the port side last night. I was very happy to verify that the boat hasn't shifted and the forms from the starboard side match the hull perfectly on the port. :cheers:
The original plan was to completely build the stringers one side at a time, but now I am going to glass them both at the same time and have an overlap of glass down the keel. This will beef up the hull there and should eliminate the need for reinforcement down the center. I will alternately lay the glass so that the both stringers will become one piece once it is all said and done.
I have also decided that the rigging tubes will run down the stringers instead of inside of them.
Now it's just down to waiting for the weekend, the temps are supposed to be 15 degrees higher than today...
Carl
April 24, 2014, 11:22:07 AM
Reply #280
« Reply #280 on: April 24, 2014, 11:22:07 AM »
Looking good, Carl :thumleft:   gotta ask...did you remember to put release agent on the forms on this one?
Also, did you include drain tubes to allow water from the outboard cavities to reach the bilge?
April 24, 2014, 11:47:31 AM
Reply #281
Callyb
  • MidWest
« Reply #281 on: April 24, 2014, 11:47:31 AM »
Quote from: "CLM65"
Looking good, Carl  gotta ask...did you remember to put release agent on the forms on this one?
LOL! :lol:  Yes, and thank you for looking out. I did mine like yours, all the way in the back at the transom. I'll have to get pics of that too, I guess.
I used 1" schedule 30 PVC for the drains.
Have you had time to mess with the Fire Boat at all lately? I'm going through rebuild porn withdrawals... :wink:
Carl
April 24, 2014, 01:14:17 PM
Reply #282
dirtwheelsfl
« Reply #282 on: April 24, 2014, 01:14:17 PM »
Custom fuel tank?
April 24, 2014, 04:27:12 PM
Reply #283
Callyb
  • MidWest
« Reply #283 on: April 24, 2014, 04:27:12 PM »
No, well not custom that I ordered anyway. It is a new old stock tank for a Chapparal boat, 55 gallon.
Carl
April 24, 2014, 05:19:40 PM
Reply #284
« Reply #284 on: April 24, 2014, 05:19:40 PM »
Unfortunately not too much.  I did order a console and a half tower though :D .  I wanted to get the console before I install the deck so that I can make sure everything matches up and I can reinforce where needed.  Then I decided to take advantage of the deal Randy is offering on the Vendor's forum for a tower (free leaning post).  I am certainly no where close to needing the tower yet, but his prices are very good and he sounds like a good guy who is trying to get his business rolling.  I figured I could help in that regard.  Plus, I'm hoping that having a nice shiny new tower sitting around will give me some added motivation :thumright: .  As for the leaning post, I always wanted one in the 205.  So it will likely end up in her, as I plan to build a livewell like yours for the flatback.
