I just talked to the guy doing the job and he's already into the rewiring and said it's not as hard to do as he first thought. He said there's a half dozen wires coming in separate from the harness and that all the switches and gauges are wired together which makes it tougher. I'm going to have to run with it and live with the results. I'll keep you posted.
Well, I got nicked for $450 for everything I had done on the Osprey at the local dealership, which included:-Removing the old and installing/wiring the new dash, including drilling three new holes for the additional gauges -Securing the new fuel sender plate with two additional self-tapping screws (I was able only to get three of the five mounting screws to 'take' when installing the new WEMA sender last month) and hooking up the wires to same-Repacking two trailer wheel bearing assemblies-Checking and replacing wire nuts with butt connectors on the bilge pump wiring How's that sound?Dan
