Author Topic: 86 Intrepid refurb  (Read 4122 times)
November 18, 2012, 02:50:48 PM
Read 4122 times
dirtwheelsfl
86 Intrepid refurb
« on: November 18, 2012, 02:50:48 PM »
1986 26' Intrepid. Current project im doing for a friend of mine. Working our way up to a full paint job, but first need to address some rotted wood core issues and some delam. Also building and in deck livewell and some other small parts. New coffin cover as well..
LOTS of room in this thing
removing rotted wood core due to poor sealing. front portions had tower legs bolted to it. culprit in the stern was a rod holder
replaced with corecell scraps bedded in epoxy. ran out so just used some pvc board in the stern
any gaps filled with thickened epoxy and glassed over while hard but still tacky.
some might replace from the bottom, which would be ideal... if it was upside down. ill work WITH gravity and just fair it in. could also have used old skin and taped the edges back together, but i feel better with a full lamination with such small surface to bond into the original laminate. plus i charge hourly :)
November 18, 2012, 02:58:48 PM
dirtwheelsfl
Re: 86 Intrepid refurb
« Reply #1 on: November 18, 2012, 02:58:48 PM »
The foam core here was all delaminated from the top skin by water intrusion through a grab handle (4 thru bolts). ground down to good core and filled/glassed.
pattern for glass
no idea how this happened, but skin and core was crushed. need to finish this first so i can get the new coffin cover on, and stop almost falling into the hole. wasted space in front of the tank bulkhead will be painted and will have an access from inside the console for storage.
couple leaning post changes apparently
all holes here drilled out and thickened epoxy injected. bad wood was localized to just a couple very bottom transducer holes. all get beveled and glassed. been told the boat originally had twins, but i think someone just changed the side the rigging came through when repowered with the e-tec, because i cannot find any evidence of a twin bracket.
im not sure why intrepid back then was vacuum bagging and foam-coring most things and then wood coring other things and not using some type of synthetic? :scratch:
 Fairing starts monday!
November 18, 2012, 07:06:31 PM
« Reply #2 on: November 18, 2012, 07:06:31 PM »
Thanks for the tutorial - always appreciate this.
I see you use wax paper - why?
November 18, 2012, 08:04:06 PM
dirtwheelsfl
« Reply #3 on: November 18, 2012, 08:04:06 PM »
Here i was using it as tracing paper for making patterns for glass to be cut. Use it for a cheap peel ply sometimes too...
November 19, 2012, 05:27:06 AM
« Reply #4 on: November 19, 2012, 05:27:06 AM »
You could put my 170 in the aft of that thing and still have room - huge.  Lots of fishing room.
Trace paper makes sense since you can see through it.
Nice big carport to work under also - boy I could have used that yesterday as I was cutting out the floor of my 170.
November 19, 2012, 01:58:57 PM
dirtwheelsfl
« Reply #5 on: November 19, 2012, 01:58:57 PM »
Yea i love this thing! Wish it was here when i was doing the flattie. My grandma has it behind her house which is nextdoor. My air hose is just long enough to reach everything. Wheres the pics of your demo?!
November 19, 2012, 07:53:57 PM
« Reply #6 on: November 19, 2012, 07:53:57 PM »
Gotta love grandma  :cheers:
I have been taking pics as I go and will save them for a rebuild post.  Yours is the topic here and I may pick your brain on layups and such as you go (and as i go).
January 08, 2013, 01:18:22 PM
gman 82 aquasport
« Reply #7 on: January 08, 2013, 01:18:22 PM »
How goes the rebuild , any pics of the finished product :salut: Like the idea of wax paper for patterns, will borrow that in the future :thumright:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
January 08, 2013, 09:03:14 PM
dirtwheelsfl
« Reply #8 on: January 08, 2013, 09:03:14 PM »
Got a bunch of pics, none too exciting though. Found more rot in the cap on the bow and console, so just fillling, glassing, fairing etc. Built a one-off livewell to drop in the deck as well.    Convinced owners to paint it white too haha!
Will update when it actually looks like somethings been done (primer etc)
February 18, 2013, 10:32:53 PM
dirtwheelsfl
« Reply #9 on: February 18, 2013, 10:32:53 PM »
More rotten wood!   This is why ANY penetration i put into wood is overdrilled and filled with epoxy.
control box mount
Lots of holes popping up when sanding started. beveled, glassed and faired..
checking fairness...
Built a livewell to drop in the deck here. The hull bottom will be the main support for it, then the flange on it will be thrubolted to the deck hatch flange. Transducer in the bottom really dictated the size and location of it, then built the rear flange/hatch divider and glassed to the deck.  Then had to cut the front hatch down and add an inch and a half or so to the rear hatch. Goal was to make it factory looking  :wink:    Hatches were also delaminating on the edges, so the core got cut back a few inches and reglassed the edgesof the core to the outside skin.
February 18, 2013, 10:40:56 PM
dirtwheelsfl
« Reply #10 on: February 18, 2013, 10:40:56 PM »
Primed up..    Going from cap to console to interior, all in primer first then finish paint. Then onto the hull, which is going to white...
Another thing i did was take a fairing board to the bottom lip/edge of the cap. Youd think a boat of this caliber (price) would have nice straight trimming done there but no, it was pretty wavy. I can see some sloppiness under the rubrail but on the inside? not gonna fly. No one will ever probably notice, but i made sure the owner knows it.
heavy repair areas..
February 18, 2013, 10:55:04 PM
« Reply #11 on: February 18, 2013, 10:55:04 PM »
Beautiful work.
That high-build primer is the deal.
February 19, 2013, 05:13:16 AM
« Reply #12 on: February 19, 2013, 05:13:16 AM »
Nice work Chris  :salut:
February 19, 2013, 09:58:47 PM
dirtwheelsfl
« Reply #13 on: February 19, 2013, 09:58:47 PM »
I cant stand sloppy cuts!   I wouldnt have let her out the door...
This is the bottom edge of the top half of the 2 piece console
lip under the seat in the front of the console
February 19, 2013, 11:30:03 PM
« Reply #14 on: February 19, 2013, 11:30:03 PM »
Quality delivered :thumright:
"When the thrill of cheap is long forgotten...quality still remains."
