Author Topic: Brake lines  (Read 808 times)
November 10, 2012, 09:52:45 AM
Read 808 times
czizza
    • http://www.dmtinc.com
Brake lines
« on: November 10, 2012, 09:52:45 AM »
I am in the process of rebuilding my single axle trailer.  I have an1997 Explorer 215 and a 1997 Loadrite.  I tow tmhe boat about 3 miles for the ramp and back.
Recently the axles fell out while towing, see my other post, and now I have no breaks. The lines are crape so I have to replace them all. Just checking if any of you guys have used the rubber line kits I see at westmarine and are they any good?
November 10, 2012, 10:59:43 AM
Re: Brake lines
« Reply #1 on: November 10, 2012, 10:59:43 AM »
I used the plastic brake line kits from Sturdybuilt Trailer Parts.  They work as well as metal lines as long as you prevent chafing.
November 11, 2012, 03:54:09 PM
kraw2
Re: Brake lines
« Reply #2 on: November 11, 2012, 03:54:09 PM »
If your not going back with aluminum brake lines use the harder plastic lines suggested. The rubber lines will be too soft for hard braking.
